- Running rich (long post with lots of detail)
- Best Lightbar Setup for a Toyota 4Runner Where to Mount and What to Buy?
- 8" v6 differential side gear
- 97 4Runner Giving me fits.
- Rear window breakdown
- 98 Tacoma 2.7 4 cylinder Resurrection
- Can swap
- occasional stumble
- Need: 1995.5–2004 Tacoma bucket seats
- 3rd Gen Speedometer Malfunction Fix
- 97 4runner 3.4 spliced wiring
- OTR replacement boots?
- Reprogram keys?
- ECU replacement
- 2000 4 WD 3.4 6cyl oil pan
- Drilling holes in the Floor Board / Rear Seat Foot Panel
- throttle body 3.4
- B03A and B03B compatability.
- Need some help Identifying Bushings - 2002 4Runner / V6 3.4 fwd
- 97 Tacoma ecu needed
- Help Please ... I removed my timing belt and the new one has no reference lines
- Supra A340e in 4runner?
- Opinion on Radiator Swap or Flush
- Brake vacuum booster
- Sluggish runner
- Rough idle + intermittent stalling
- 99 4runner 5 speed, gurgling engine noise under load
- 2002 4R manual swap electrical questions
- 4Runners + Surf + Hilux ECU's
- Cs144 alternator prongs?
- Heat shields for thorley headers?
- Misfire - ECU Bad?
- 3.4 rebuild
- how to get to supercharger lower bypass o-ring
- Driver's side mirror replacement
- White Flakes in Oil
- What is the exhausts exact size for adding a exhaust tip?
- Replacing Headlights With LED Bulbs
- Can’t seem to figure out this P0172..98 tacoma 3.4
- 2000 T4R misfire on startup
- Gears with 285/17's
- Source I cannot find again ! R150f manual transmission part
- Headlight Issues
- Misfires and frustration
- MegaZip Parts
- r150f output shaft bearing removal force and method
- Shocks replacement with 3" lift.
- RR diff light on cluster
- 99 Taco - what are these connectors?
- 1st gen tacoma cab 3rd gen frame
- Please someone help me toyota4runner
- 2001 4runner turned it off acts like I dropped a valve
- Front end clunk
- Rebuilding the Alternator?
- 2003 Taco - SPC Adjustable Upper Control Arms Don't Fit Steering Knuckles
- Looking for transfer case
- Aluminum handle
- Manual Trans wire Harness
- 97 Limited - New bell cranks, stuck equalizer pivot help
- T100 3.4 5spd transmission in 3rd gen T4R?
- 98 Ltd Sunroof Service
- ISO wire harness pin part numbers
- 1998 4Runner Limited 3.4
- 2000 4runner limited tranfer case
- Urgent need of help with misfire codes and loud engine
- Help security light always blinking
- P0171 - "System too Lean" Bank 1. Cleaned MAF Sensor.
- P0446 Code
- Son’s 98 2WD broke at the ball joint
- 5vz NO CODES starts and idles but bogs when opening throttle
- Sun Gear Race/ Needle thrust bearing
- 3.4L 5VZFE Engine Noise Asking For A Friend
- 2003 Tacoma 3.4 quad cab 4wd.
- 96 4Cyl 4x4 2.7 Radiator Replacement
- P1300 and no start after changing plugs
- 3.4 swap with harness and computer
- 2001 Tacoma 2.4L Fuel flow shutoff - Relay? Safety switch?
- '96 "Whistling" noise
- Trying to get back to stock with my '99
- 98 4Runner sr5 Interchangeable rear enda
- A note on the Tundra front brake upgrade
- 01 4Runner CEL P1760
- Which Electric Fan?
- 97 4runner IAC P0505 setsimmediately
- Online Manual link dead?
- 3vze 4R A/T still revs, drives, losing power
- Electrical Issues
- Hello All! 1999 Bouncing at 60+ Mph
- 98 Tacoma won't start
- Rear diff backlash adjustment
- 01 runner 4wd not working!! Need help
- 4WD activating randomly
- Did the ELM327 dongle fry the ECU?
- Harmonic Balancer Issues. Is it fine to drive?
- 98 4Runner Sr5 2wd to 4wd Conversion
- Converting 98 3.4 4Runner to 4x4
- 96 Tacoma 4 Cyl 3RZ Power Steering Tensioner Pulley
- 5VZ-FE Swap Maximum Engine Coolant Temperature
- Help me pick 3rd gen 4runner
- Transfer case grinding when trying to engage.
- 98 3.4 Toyota 4Runner SR5 Misfiring
- Wanting to lift my 2002 4runner
- 98 3rd Gen Sr5 upgrades
- Gauge cluster fuse keeps blowing
- 3rd Gen 4runner REAR Auxillary 12VDC Outlet
- What is this noise and where am I goin wrong
- 98’ 4Runner typical acceleration issues
- What is this on my end link spline?
- Two types of bump stops?
- Repair or replace?
- Leaking ganjo bolt on 98 4runner
- Driveshaft Component Compatibility
- 2RZ: Tips to reach the EGR coolant hose clamp against the the firewall?
- 98 4runner wheelwell fastener
- UCA options
- UCA options
- Reworking and Repair
- Radiator Swap
- Help needed with 3.4 v6 misfire
- lift components opinions.
- Transmission? Torque converter? Solenoids? HELP!
- Tundra Front Coils
- '98 SR5 4Runner - Keeps killing batteries
- Rear Diff lock not engaging
- Taco/4Runner seat FRAMES the same?
- 2001 tacoma rough idle and stalls/dies on acceleration
- Helpful tool for 1st Gen BRAKES?
- 97 4Runner failed NOx GPM emissions
- Whining sounds from 1st through 2nd gears
- My New Toy
- Need advice on 99 4Runner
- 4x4 light coming on when 4x4 not engaged
- Help replacing alignment cam bolts
- Too much fuel??
- Can rear shocks from a 2nd gen be used on a 3rd gen 4runner?
- Smoky and milky after head gasket replacement
- Anyone use AI to help with repair info?
- RH Brake Light No Work, All Other Lights Work
- Is this a speed sensor or ?
- Where’s the wire?
- Cracked Head?
- 96 4runner transmission to 2000 conversion
- Aftermarket Cats?
- Fried everything, engine swap.
- 5VZFE Cylinder head flow numbers
- turing . . . eer turning test for rear axle identification
- exhaust burping after new spark plugs
- Now what? Rebuilt Motor Broken Cam Bolt
- P1300 and EFI
- Stubborn ignition cylinder
- Rear defroster and rear window not working
- P1300 but running fine
- ABS codes quick question
- Overactive Traction Control, I think?
- Need help finding part
- rear axle bearing gone south
- What's this funny bolt hole in my block?
- TPS response
- Dropped bolt down timing chain opening :(
- clicking noise
- Troubleshooting a Zombie Starter
- 1996 4Runner attempted break in now driver door broken
- Should I Buy This 3rd Gen?
- Can somebody please explain this DRL lighting circuit to me?
- 1997 4Runner Transmission Clunk
- Its broken, what do I do.
- Mechanic in Rockland county NY?
- Xinoki 2002 4runner: Piston Install 5VZFE
- What Diff is this?
- 99 Tall coils on 2wd?
- Misfire, knocking.
- Method For Troubleshooting Fast Blinker (not a bad bulb, not LED)
- In desperate need of wiring harness for 96
- Hard brake issues
- 4wd "limbo mode" issue
- 4Runner no more
- 2000 4Runner SR5 - Chassis Lube / Maintenance
- Coolant under intake manifold 3.4L
- 2001 4runner door locks
- rear suspension question
- Evap canister issue
- 1999 4Runner Sr5 misfire black smoke
- Can anyone guess at the size of these tires?
- Vacuum lines
- Supercharged 3.4 lean condition
- New throttle body no more high idle!
- 2000 4Runner SR5 overheats while idle with A/C turned ON
- Tubes on top of throttle body
- 97 verse 98 4runner
- No codes knock/miss 95 Tacoma 2.7
- 1-2" Lift - Longer Sway Bar End Links?
- Idling issues. Cannot find the culprit
- Front Differential
- Crankshaft key salvagable?
- What parts list for a brake upgrade?
- I May Have Really Done it This Time....
- 2001 4Runner 3.4 changing misfires
- Checking trans-fluid: When cold, well above the hot-line. When hot, below the cold.
- Fuel pump and COR
- Timing belt came without any marks!
- Squeaky Brakes After Change
- Wire Headlights To Ignition
- Problems after Tundra Brake Upgrade
- How bad is this??
- Questions while replacing knock sensors
- 96 Taco Cleaning Cat Converter Unit - Anyone?
- Window sticker style changes?
- Codes for knock sensor 1 vs 2
- Frame swap
- Manual transmission whine
- 2000 4Runner slight hesitation when accelerating from stop
- 4Runner hood scoop water entry
- Which obdii protocol for 1996 to 1999 Tacoma?
- 2000 4Runner 2wd auto trans issue
- Transmission Sounds
- Steering Rack bushing replacement - 2000 4Runner SR5
- Caster adjustment
- 3.4l swap question
- 98 4runner keyless remote
- Auto to Manual transmission and j-shift swap
- Napa Drums and Sticking after Wash
- Air leaking at passenger feet?
- 98 4runner rear heater inoperable
- Hard Start 98 2.7 Tacoma
- Knock sensor, Pigtail wiring, Gaskets, and rockauto
- Shifter play
- '96 4Runner won't start.
- Automatic car wash got my Tacoma
- Rear differential housing rust pinholes leaking
- No power to radio or antenna
- 1996 Purge Valve
- 97 4Runner IAC issue
- jolting engine problem 98 Tacoma 3.4 4wd manual
- 2001 sequoia to 3rd gen 4runner caliper swap
- Andy Mod 02 4runner
- A340F Tranny rebuild recommendations?
- Help Diagnose Clutch/Tranny Noise
- ECU pin diagram
- Floor Jack Recommendations
- 3rd gen 4runner hangs in 3rd under acceleration, drops to 4th/OD when you let off.
- Understanding the ADD and centre diff actuators in a 3rd Gen
- Tightening crank pulley bolt to spec.
- Power steering 1998 4runner 2wd
- Looking for a mechanic for 96 Hilux Surf in Mid Tennessee.
- 1999 Taco Prospective Purchase: MT vs AT
- 1997 Taco Camper Shell suggestions
- Spontaneous headlights?
- No power to AC compressor
- 1998 4runner MT shifting difficulty
- 5VZ-FE Low Compression Question
