Misfires and frustration
Old Jan 31, 2025 | 11:36 AM
Williewilly's Avatar
Recently my 2004 3.4L Tacoma started misfiring, never threw check engine light but I could obviously feel it. Checked the codes and there was a cylinder 6 misfire code, but also doesn’t stay in 1 specific cylinder. Long story short I’ve replaced the injectors, coils, coil wires, spark plugs and ignition control module, and still have misfires. Coolant and oil levels are all the same. Engine doesn’t even have 190k on it so I’m just wondering if anyone else has had a similar issue.
Old Feb 3, 2025 | 05:08 AM
Paul D.'s Avatar
Timing us usual suspect
Check your timing. Grab a timing light and see if its correct. If not, check your timing belt. When was it last changed and could it have jumped. If so, change it. If its good, check the camshaft position sensor. It might be bad. Lastly, you computer might be bad.
rcbrown23
Feb 5, 2019 09:55 AM
chicago60647
Feb 22, 2018 12:47 AM
SO/TX
22
Jul 13, 2011 11:21 AM
chris360hawks
Sep 20, 2010 07:42 AM
VML4runner
42
Mar 2, 2010 09:05 AM
