Method For Troubleshooting Fast Blinker (not a bad bulb, not LED)
Old Sep 29, 2023 | 06:12 AM
83's Avatar
83
I'm assuming this is a wiring problem. I had a fast blinker on one side, sometimes...replaced the bulb. Still fast sometimes. Now I have both left and right fast blinkers, but only occasionally. I'm assuming wiring, but my electrical trouble-shooting skills are pretty weak. I have a volt meter.
Where should I start looking, and how do I track this down?
Old Sep 30, 2023 | 01:53 PM
2ToyGuy's Avatar
Try pulling the fixtures off the truck, and check the ground to the body on the back? They are prone to corrosion. and thus you get the rapid flash.
Worth a look...
Pat☺
Old Oct 3, 2023 | 05:59 AM
83's Avatar
83
Thanks! I'll check the connections soon. Been rainy and I don't have access to a garage right now. At the same time, I've been noticing my brake light coming on now and then, which is what made me think it might all be connected and be wiring, but they may be separate issues.
Old Oct 30, 2023 | 06:06 AM
83's Avatar
83
Hard to say for sure what the blinker issue was but I cleaned all the connections in the actual blinkers, and replaced the front right assembly since the lens was cracked a moisture was getting in. That solved the occasional fast blinker. Brake light was from slightly low brake fluid. It all seemed to happen at once so I was thinking there was something bigger going on with the electrical system, but luckily not.
Old Oct 30, 2023 | 09:18 AM
det107's Avatar
Didja add the required blinker fluid?
Old Nov 1, 2023 | 07:04 AM
83's Avatar
83
I check that before every drive.
Old Nov 4, 2023 | 08:10 AM
Malcolm99's Avatar
Try disconnecting the trailer wiring 5 wire to 4 wire converter, maybe it is effecting things, they do go bad as an add-on over time.
Old Nov 6, 2023 | 05:53 AM
83's Avatar
83
Thanks Malcolm. I actually remember reading the reviews for the trailer wiring before I bought it, and a few mentioned their experience that they go bad every few years, so to expect it. Mine's going on 7 years so it's likely time...
But so far, my issue seems fixed.
23
Jun 12, 2014 11:09 AM
mike73737
Apr 28, 2010 05:56 AM
89trknwby
Mar 13, 2008 04:49 PM
Tacoma750
Oct 9, 2007 02:20 PM
Andrey
Jun 27, 2007 10:30 AM
