- Extended studs for top mount/plate - alternative sources
- Tacoma Land Speed Record
- Transmission - Hesitation from Stop
- CV's?
- new 2004 prerunner
- Timing belt help
- Look at these Spark Plugs
- Please HELP - Westland Michigan
- does this look like it has a locker in it?
- 99 springs not level
- SEARCHED: Budbuilt Skid with 1" Diff Drop.
- Lights
- Brother inlaws 97 tacoma...cheap lift?
- getting rid of the limited look?
- Sacramento Help
- My 4runner antenna is fine for now but...
- Code Reader for 3rd Gen.
- Will these wheels fit a 99 4runner?
- 3rd gen 5spd conversion complete- 1 question
- Timing Belt Etc...
- What should I do next to my truck?
- My 1st $ Runner :)
- Keep blowing brake lights
- Gears
- Owners Manual
- 3.4 V6 EGR Situation
- Starter/cost/difficulty to install
- Tacoma front end conversion
- Aggressive Bumper
- Front diff 86 4x4 carrier
- 3" revtek lift - cv boot problem
- Brake pads and rotor question
- Seafoam treatment
- Skid Plate options for 3rd gen runners
- Thinking of a body lift+tire/gearing questioin
- Thinking of a body lift+ lift
- Small vibration issue after lift
- 3rd Gen - rear window goes down by itself!
- CVs Trashed???
- Disasterous ride home... Need Parts
- Is the cargo door brake light supposed to blink?
- Need a test rig! Carson city area (Also group buy offer!)
- 2001 4runner - thinking of buying, anything to look out for?
- Needing a test rig! WI area
- ski bike kayak factory rack?
- Needed: Rebuilt Transfer Case '99 Limited
- SR5 to Limited Need 'stuff'
- Clock/radio not working.
- LF 4runner recycler I would prefer one in Canada .
- Replacement Steering racks
- Rear axle seals
- NGK Iridium Spark plugs- single electrode OK?
- Have a say in what i paint my flares!
- My new 01 Taco...
- What is back spacing ???
- check engine light after loose gas cap
- 3rd Gen 4Runner Body Lift Install
- Help WANT TO SELL
- grinding noise
- 3rd Gen Runner with a 2.7
- would this be illegal
- Pics of me playin on some tires
- 3rd Gen 4Runner - slight rush on bumper + hitch
- Anyone know what's happening here?
- Backup lights not working, Bulbs, and wiring looks ok however...
- Where can I get this trim piece? (97 Limited)
- What to do while skid plates are off?
- Hole in Radiator
- Injectors cleaned for $19.95 ?
- Where to buy a cat. converter
- Pictures of lifted 4runners
- 99tacoma scoop hood fit a 3rd gen?
- Removing Bed Liner
- the new truck! pics!
- 1997 4Runner Steps & Wheel Flares
- New battery, problems..
- Finally 97 2wd 4 cyl lift
- Let's See some Tacos :)
- New Head Unit install without Wiring Harness
- 99 4runner Soft brakes HELP
- Lets See Black Rims on a 3rd gen
- Add leafs to my tacoma rear springs. Should I do it?
- New Lift with new vibration
- VIS Carbon Fiber Hood Group Buy
- What to order for drum rebuild?
- Shock Change
- Diff Dropped yet still vibrates
- Installed lift and tires.
- cold air intake
- More Power
- What is this
- Tire Manufactures that Make 35x10.5x16
- Anybody parting out 96-01 4wd 4runner?? (need 4wd vacuum solenoid)
- Denver, CO shop to do wheel bearings
- 5vzfe Valve Covers
- Starter bolt problem 3.4
- CB install on 2002 Taco 5spd.
- ROTA Countersteer pics
- help! will these fit?
- E-locker w/cable op, opinions wanted!
- 99 prerunner reverse squeak
- I need new tires and I have 4 choices .
- JBa exhaust
- Seat Support Question
- Tacoma Coilover Suspension Options
- transmission problems?
- Cleaning a TrueFlow with K&N crap.
- Making a Custom Muffler...
- Need part identified in window hinge. PIX
- getting more horsepower
- 2wd 97 4runner mild lift?
- What to look for 2002 4runner sport edition
- 96 Tacoma won't stay running
- Lets see your TACOMA's
- redline 75W90 NS
- Another Lift Option - Rancho Quick Lift
- Which 4runner to buy? Decisions, Decisions...
- For Sale: 98 LTD Parts
- Need tire and lift help!!
- Penny wise, and Pump foolish?
- installing new tires
- Fixed one rubbing, caused another
- Is anyone going to be at Chinaman on Aug 14th
- Auto Shifter Stuck. Oops.
- Eagle 102 Alloys.
- Throttle Cable adjustment on 2002 Taco (pix)
- exhaust help
- bumper help
- 4x4 clubs
- Need exhasut help please
- Husky liners
- weird problem
- Shock Install Thread ?
- Offroading.. Gone bad
- Hows this setup?
- Setup with TRD/890 and Xtreme MTs(pics inside)
- t case ratios.
- 99 runner no start issue
- 2001-2004 Tacoma Double cab Feedback?
- Shrockworks bumper for 3rd gens & Tacomas
- Problem with shifter (auto trans)
- Help with rolled 03...
- Advice for 03 taco rollover...
- Replacing Front Shock/strut on a 01 Taco
- Mystery Leak WTF?!?!?!
- Leaking Antifreeze
- speedo lags and my car won't go faster than 120 kph
- Heavy Duty Radiator for 97 4Runner
- I need some 1/4" wheel spacers, please
- New flash
- 99 coils front and OME 903 rear setup
- Cross Country and back Preparation
- new 2002 TRD SR5 Taco owner.. Tips and advise?
- SAS conversion 4x2 to 4x4 is it possible?
- ? on Headers for 3.4 with 2inRB BL
- Rear window quit working.. then started again?
- Blown axle seals, how safe to drive?
- 99 springs and kyb monomax shocks
- Doing the Lift Right
- 2000 Tacoma 4.7l V8 swap
- 3rz performance
- Exhaust is strong smelling
- 1995.5 Tacoma's OBDII compliant?
- What else should I change out when installing new springs on 97 2wd?
- Non supercharged Ping in the 3.4 ???
- A/C and engine studder
- torque specs??
- Radiator leak help
- yakima copperhead
- Chevy Light Bar Installed!
- AC Fan will NOT Shut off...What gives?
- Wheels for a Tacoma 02
- no more ECT what gives
- Clunk during acceleration
- multiple evap codes
- Problem with Bilsteins
- Emergency/parking brake help
- Will a 15" wheel fit on a 98 Limited
- How do I know my wheel bearings need replacing ?
- Air Fuel Ratio Sensor Gasket
- Pics of my 7th injector install
- Hitch and 285's?
- Does a 4.56 elocker really exist?
- wheel hop
- What's the Biggest you've pulled out?
- Two Tundra Coil Spring Questions
- Are all 3rd gen running boards interchangeable?
- WTB roof rack
- Finally new tires - Toyo Open Country MT's
- Aftermarket fog lamp wiring.
- 96 4 runner tranny swap question
- WTB: OME Coils/Shocks for 99 4runner
- What lugnuts do i need
- Someone should snag this! Tundra OE Rims
- New Lighter Tires and Rims + Turbo = Good!
- soft top canvas
- Tools for Deckplate Mod
- Good online parts houses?
- 2002 4runner Double Din?
- Larger Tacoma Mirrors?
- How high is to high?
- Parts Fitting--the never ending Saga
- CD Player/Radio and Clock Won't Work...
- Represent your school!!!
- Seaform?
- [PICS] My 02 SE 4Runner!
- what does the trd 7th REALLY get me and how to tell if its working?
- Ignition sense
- anywhere inexpensive to acquire a new heater/ac fan?
- Post OME install...pics, newb needs adivice
- Auto tranny/ rear end clunk...
- Quick help with 3rd gen 4Runner shifter handle please (automatic).
- should i buy this 98 taco? trd sc, lifted, 33", etc...
- Shock question. I searched
- strut mounts
- Got bored, here's the result
- 7th injector help ASAP
- Pics of what replaced my '99
- CB Antennae on rear bumper
- 3.4 sparkplug havok
- power and miles per gallon
- Annoying cruise control problem
- Brakes for 2000 Tacoma
- Help....replacing LCa bump stops
- Bye Bye Running Boards..Hello Sonoran Steel
- random metal part off my runner
- Supercharger and URD kit install wen't bad
- Two steps cooler plugs= worse mileage?
- Field Monitor currenlty on Ebay for sale
- I/M Readiness emissions error
- CEL on, then off?
- New Truck, Questions!
- Rattle from the Center/ Rear End of my truck
- 97 4Runner Ltd Tire Upgrade
- My official FAREWELL YOTATECH FRIENDS thread...rig is sold (LOTS O' PICS)
- Weekend Mods (56k ye be warned!)
- R/R/I starter......boy was my sweat for not.
- What Air Filter do you use...
- Guys with CB antenna mounted near the rear hatch.. need some help!
- Lucas UCL and injector cleaner
- handful of codes, how bad are they?
- 2002 toacoma CEL p1135
- Thinking of a Runner
- snorkel install
- Slider installation in Nashville Tn area?
- Hood release mechanishm, sticky, cable maybe?
- Contacted seller on 2000 TRD, here is what he said....
- Frame question
- Clutch Start Cancel Button
