99 prerunner reverse squeak
Old Aug 16, 2007 | 11:34 AM
tacolover84's Avatar
I have a 99 prerunner that recently started to make a very pronounced squeak when backing up. The sound seems to be coming from right where the driveshaft enters the rear end, but I am having trouble diagnosing the actual problem. has anyone else had this problem and if so, were you able to find a solution?
Thanks.
Old Aug 16, 2007 | 11:41 AM
gilby4runner's Avatar
U joint going bad
Old Aug 16, 2007 | 11:46 AM
Thanks for the response! That was my first thought, but I got under there and it sounds like the squeak actually comes from below the u-joint right at the point where the drive shaft enters the rear end. Have you heard anything like that before? I did add more grease to the u-joints, though.
Old Aug 16, 2007 | 11:48 AM
Embfixer's Avatar
Have you tried servicing the drive train? I had something like that on my 03 Tacoma. It turned out to be the slip on the driveshaft needed greased. I believe it was caused by excessive underbody washing with a pressure washer.
Old Aug 16, 2007 | 11:54 AM
I did re-grease, but I will do it again, as the problem persists. Really trying to avoid taking it to a shop to diagnose, b/c I do all my own mechanic work, but I am just having trouble diagnosing the actual problem.
Old Aug 16, 2007 | 12:08 PM
Embfixer's Avatar
It took a lot of grease and I also sprayed down the imput shaft to the rear with a lub. Did it start after an under body washing or driving through water?
You could jack one rear tire and put the trans in N and spin the shaft by hand and get some good T/S.
Old Aug 16, 2007 | 12:13 PM
Neither, actually. Drove back from Mexico on Sunday, problem didn't exist when we left. Got home, and noticed squeaking when I backed into the driveway. I don't recall any water. I didn't use that much grease b/c i didn't want it spraying everywhere, but I guess that doesn't really matter. I will add more. I also sprayed the input shaft with a silicone lube already, with no change resulting. Thanks.
Old Aug 16, 2007 | 12:14 PM
What is T/S?
Old Aug 16, 2007 | 12:18 PM
Embfixer's Avatar
T/S = Trouble Shooting. Maybe your brake shoes too. Good Luck!
Old Aug 17, 2007 | 08:31 AM
I greased the ish out of it and the squeak is gone!! Thanks for all the god advice guys!!
Old Aug 17, 2007 | 09:14 AM
FyrHazard's Avatar
I had the same problem after a long road trip - greased the u-joints and slip joint and it went away. Probably should've greased them more often beforehand
punks_is_4x4
Sep 19, 2015 05:52 AM
JookUpVandetti
Sep 17, 2015 09:25 PM
scheuvront1993
Sep 17, 2015 06:17 PM
May-39
Sep 6, 2015 01:05 PM
matthew138
Sep 3, 2015 08:21 AM
