CVs Trashed???
Old Aug 21, 2007 | 03:10 PM
4runnin2002's Avatar
CVs Trashed???
k out wheelin playin with the new ome lift on.....go up a rock and driver at full droop and turn towards passenger....loud snap....check the shafts and then see the fluid from the CVhttps://www.yotatech.com/forums/images/smilies/banghead.gif
....now it has the boot and ring, no tears, and it just looks pulled off....can this be fixed or need to be replaced??
Old Aug 21, 2007 | 03:23 PM
exacto's Avatar
depends on what you broke on the cv axle.
if its a lot of parts and they add up, go to your nearest junk yard and look for a used cv.
new cvs are a lot of money.
Old Aug 21, 2007 | 03:24 PM
wjwerdna's Avatar
sounds trashed... post pics?
Old Aug 21, 2007 | 03:25 PM
wjwerdna's Avatar
new cv's are <$100??? right?
I've been fortunate enough to make mine last so far
Old Aug 21, 2007 | 03:27 PM
cant get my pics to work idk....i'm workin on it....and whats worst situation with it messed up??? my buddy talked bout takin it out till i can get a new one in....whats worst situation wit that
Old Aug 21, 2007 | 03:33 PM
k lets see
http://s225.photobucket.com/albums/d...current=CV.jpg
Old Aug 21, 2007 | 03:43 PM
Skrillah's Avatar
Yeah thats a problem! You can replace the boot but to replace the whole axle itself is much easier and more worth while in the end.
If you have an Advanced Auto Parts, they have new CV axles for $80 with a lifetime warranty and no core charge. You can't go wrong there, I just recently picked some up myself, and am now just faced with the challenge of putting them on. From what I've read its not too terribly hard, so I may give it a try tomorrow, I'll let you know.
Old Aug 21, 2007 | 04:09 PM
wjwerdna's Avatar
uh sir, that beast looks torn,
may as well replace the whole thing if it pulled apart enough to tear... did it drive ok after that? if so it seems that would mean the core part of the cv was still intact, but either way the boot at minimum would need replacement, and may as well replace new axle
make sure you have done a diff drop (search if you dont know)... and if you don't know, you don't have it, and you should
also, new sway bar end links? stock or discos? they look shiny in the pic
toy_tek's Avatar
You can either replace the boot or replace the axle. Boot is cheaper, Axle is easier. I'm not going to recommend one way or the other because each has its advantages: see the 2nd gen thread that's going for opinions on either side.
But, on the 3rd Gen you can not run with the axle removed. You will leak front diff fluid as soon as you pull the inner shaft from the diff. Not really sure you can do that with any vehicle - I wouldn't.
Whatever you decide, its better to fix it sooner than later.
Old Aug 21, 2007 | 04:11 PM
wjwerdna's Avatar
or you can bust the rest of the axle apart, stick the chunk back into the front diff to keep it from leaking (both sides) and be happy in 2wd...
note: disregard above if you are either in your right mind, or unless you are stuck in the desert/woods somewhere
Old Aug 21, 2007 | 04:32 PM
frodin1's Avatar
I've heard that they aren't that bad on the wallet "aftermarket". It doesn't look to difficult to change out either. I've heard you'll need a loan to get it done at the dealer though. http://www.4x4wire.com/toyota/maintenance/cv_axle/
Old Aug 21, 2007 | 07:58 PM
the boot doesnt actually look torn in person my phone is the only cam i can load on to my comp from....the ring is still on the boot, boot still intact and all just pulled off of the rest of the cv i guess...but i'm almost sure there's some ball bearings out near where i was wheeling....and it drove ok just sounded like a roller coaster going up the chain....and the fluid....pretty sure its all gone now as it sprayed out.....POOP!!!
diff drop....this was me takin a short cut....didnt order it or get it done i figured it would be ok...lets just say lesson learned and leave it at that ordering ASAP from Steve!!!
new?? no not so....ah...thats the pic and fluid on it....
Old Aug 22, 2007 | 12:11 AM
BornChaos's Avatar
It's probably been said already but since im in such a good mood:
It's much easier and more effective to replace the whole CV axle.
Remanufactured CV axles can be had from Napa for around 100 bucks after you bring them back your core axle (or if you do that first, whatever.) They have lifetime warranties too I BELIEVE. Thats what the guy told me, but he seemed unsure at first. I live in SoCal where things are f*ing outrageously expensive, so I have heard of people getting them for less in the boonies (non CA).
Here is a write-up that is pretty good:
For more information you can search here on replacing CVs.
Firefightersink15
Nov 23, 2015 10:32 PM
sonorn67
Sep 19, 2015 05:39 PM
meatballs
Sep 16, 2015 06:25 PM
Cwolfe
Sep 12, 2015 12:23 PM
boogiewoogie
Aug 29, 2015 01:03 PM
