How do I know my wheel bearings need replacing ?
Old Aug 7, 2007 | 06:08 PM
pfbmgd's Avatar
I have a 183 000km on the runner .How will I know if the bearings need replacing ?
Old Aug 7, 2007 | 06:33 PM
frodin1's Avatar
There's a number of different things you can do to determine this. A quick easy check , is to jack up the wheel that's suspect, and shake the tire and wheel. You can usually get a loose, rattle type feeling out of it. I dont know how else to descibe it but you'll know what I'm talking about if you feel it. Also, If you have any noise like a bearing squeal, that's another hint. Then again, you can always take it apart.
Old Aug 8, 2007 | 06:07 PM
pfbmgd's Avatar
How much does it cost to replace the bearings ?Is it a easy do it yourself job.
Old Aug 8, 2007 | 06:40 PM
MARSHALLMAY's Avatar
It only takes a few minutes to pop the axles out. But you need a press to easily remove the abs collar and bearing. If you don't have access to a press, you should take it to a shop.
I'm not sure about a price.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
Gamble_STi
Jul 7, 2015 07:54 PM
skoti89
Jul 6, 2015 07:45 PM
colinmil
Jul 6, 2015 04:03 PM
