Non supercharged Ping in the 3.4 ???
Old Aug 9, 2007 | 10:11 AM
nrgetic99's Avatar
My 98 Ltd has 140k on it.
Under load, typically at wide throttle openings, I am getting Ping or pre-ignition. Its very consistent and noticeable, to me at least.
This can really only be due to ignition timing, poor fuel quality or a heavily coked top end.
I am pretty sure the ignition timing is set and not adjustable by me so unless I have bad crank sensor, its fixed.
Anyone else experience this ??
Thanks
David
Old Aug 9, 2007 | 10:33 AM
mt_goat's Avatar
Have you tried a higher octane grade to see if it helps?
Old Aug 9, 2007 | 10:48 AM
ARB1977's Avatar
If you need higher octane that generally means your pistons maybe caked with carbon which will increase compresson.
Old Aug 9, 2007 | 11:23 AM
mokai's Avatar
Try Chevron fuel..Toyota recommends it highly..I had that prob before getting S/C'ed and using Chevron fixed it..I was using bargain fuel..Also maybe a fuel system cleaner would help..
Old Aug 9, 2007 | 11:34 AM
LuminoZ's Avatar
just a question... how many miles do you have on your plugs?
Old Aug 9, 2007 | 06:48 PM
UNR.Grad's Avatar
I get the same thing, especially right around 3200 when it is about to up shift. I cringe every time I hear it. I only use chevron gas, but maybe if a run a few things of techron through the tank it would help. Also my plugs are very old, I haven't gotten around to changing them, would that affect it?
Old Aug 10, 2007 | 01:33 AM
AppleJack's Avatar
My '99 does the same thing and as far as I can tell there is nothing that I can do about it. I've tried premium gas, cleaned the system, new fuel filter, new plugs, gave her the Seafoam treatment, and it still pings. I have noticed that it pings most in hot weather. I don't really have the problem in winter. So I bought and amp and sub and just turn my stereo up so I can't hear it. I hate that sound!
Old Aug 10, 2007 | 03:05 AM
excableguy's Avatar
That's odd--within the last week or so I have had 2 instances where I get a big loss of power followed by what sounds like a lot of pinging. It kinda sounds like a little diesel or what a car would sound like using leaded gas! I took the go-or-blow approach, and it seemed to get past it, but I would love to know what is causing it--I've had ZERO problems out of my runner up until now.
Old Aug 10, 2007 | 03:25 AM
excableguy's Avatar
Anyone checked with toyota mdt tech? From the older posts I've read he's pretty slick--I might PM him about this and see if he has dealt with it.
Old Aug 10, 2007 | 06:30 AM
nrgetic99's Avatar
Thanks all.
I am going to do all the normal stuff this weekend. I will check my plugs but I have less than 12k on them.
I do believe its a combination of gas quality (MTBE in summer) and a coked top end. I do run a fuel cleaner every 3000.
I will then run mid grade for a tank and see what happens, however, that will just confirm that either the top end is coked or the timing is out.
In a pinch, I could try running a cooler plug but with all the city driving I do, fouling is a real possibility.
David
Old Aug 10, 2007 | 06:54 AM
mjwalfredo's Avatar
Giving coke to your runner cannot be good... Seriously though, nobody has mentioned cracked/bad ignition wires. That can sometimes be a problem around the mileage you are at David.
Old Aug 10, 2007 | 08:55 AM
AppleJack's Avatar
Let us know if you find a cure, sounds like a pretty common ailment.
I have a friend who had an '05 Taco and it was plagued with the "ping". He took it to the dealer service shop a number of times but nothing ever worked. They even replaced the fuel pump. He decided to trade in for an '07 and has had no ping problem with this one. I guess some have it and some don't.
Old Aug 10, 2007 | 09:50 AM
excableguy's Avatar
Is it intermittent with you guys, or is it all the time? The times mine has done it has been from out of nowhere, and only lasts momentarily. I noticed that the first time it happened to me it was 90+ degrees, and that my 4runner had gotten the hottest I had ever seen it just a few minutes prior from sitting and idling for 20+ minutes in a parking lot. Then it acted up on my wife yesterday...
Steven.m.paulk
Jun 7, 2020 10:45 AM
primordialbeast117
Dec 19, 2015 12:23 PM
White Stripe
Oct 6, 2015 10:47 AM
LCE_Performance
Oct 1, 2015 01:03 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
