Cleaning a TrueFlow with K&N crap.
Old Aug 15, 2007 | 07:47 PM
Nate08's Avatar
Can you use the K&N oil and stuff to clean a TrueFlow? AutoZone has the little airfilter cleaning kit them K&N. I dont wanna have to order the TrueFlow kit offline if I dont have to.
Old Aug 15, 2007 | 07:54 PM
amgraham's Avatar
If it's an oiled gauze type filter then yes, you can use the K&N kit. I use that same kit to clean my cheapie ebay filter too
Old Aug 15, 2007 | 07:58 PM
Nate08's Avatar
Okay, thanks. I'll have to get some. Just got back from a camping trip driving on a dirt road for a 8 miles behind a Suburban one way and a F=350 the other. Its looking pretty nasty.
Rescue84's Avatar
The K&N is a gauze type filter, the TrueFlow is a foam filter, while the cleaners and oils are most likely pretty similar I went with the TrueFlow cleaning kit just in case... I'm sure someone will chime in with a little bit more insight, I just played it safe with mine. Good luck.
Old Aug 15, 2007 | 08:00 PM
Nate08's Avatar
Gees Im an idiot. I was thinking gauze as foam. I knew what I meant, I just read it wrong....haha.
Old Aug 16, 2007 | 01:21 AM
rocket's Avatar
Do it right and buy the True Flow cleaning kit. I bought mine a couple weeks ago here...
http://www.autoanything.com/air-filt...A1964A0A0.aspx
Free shipping and it arrived within 3-4 days. I hated spending the money but the results were well worth the cost.
Old Aug 16, 2007 | 04:25 AM
breknraj's Avatar
The other aspect of this is that you popped for the TrueFlow in the first place - why cheap out on the cleaning kit that you should get a number of cleanings out of?
BTW - The instructions for the TrueFlow specifically say NOT to use guaze filter cleaning kits. Something about the filter oil being the wrong consistency for the foam, if memory serves.
Bottom line, just spring for the kit that is made for your filter!
Old Aug 16, 2007 | 07:49 AM
Rock Slide's Avatar
Agree with what others have said. You opted for the True Flow kit, so you might as well get the proper cleaning/oil kit right? Don't let a little more $$ and a few days shipping time keep you from buying the TF kit.
That's like saying you could buy a cheap oil filter (insert brand of your choice) from walmart, rather than going to the dealer, b/c walmart's closer. Just b/c the item may work okay in your vehicle, doesn't mean it's the best for your truck.
I ordered my TF cleaning/oil kit online w/ free shipping and I had it in a couple days. IMO, stick w/ the TF kit.
Colington
Mar 8, 2020 09:51 AM
Yota.Jay
28
Oct 22, 2015 01:08 PM
Jason Webber
Sep 2, 2015 03:30 AM
ManzDaKlown24
Aug 22, 2015 10:25 PM
jjrbus
Aug 10, 2015 01:09 PM
