handful of codes, how bad are they?
Old Aug 1, 2007 | 10:27 AM
northfacer581's Avatar
so i just had to replace the bulb that illuminates the ac controls, and my cel light was on, but usually its been the 02 sensor, which is good, there is just some issue that toyota cannot workout but says if 02 code pops up, dont worry about it. well....i got 4 more codes pulled today while i was at advance auto, and i need to know how serious of a problem they are, and if i need to get them (mostly sensors) replaced:
P0100 Mass Air Flow
P0120 TPS/Pedal Position Sensor A
P0136 02 sensor Bank 1 Sensor 2, (i think its ok)
P0340 Camshaft Position Sensor A-Bank 1
P1300 Manfacurer Contrl. Ignition System or Misfire
thanks for any help
Old Aug 1, 2007 | 10:42 AM
yotamaster1988's Avatar
lol
those are all bad codes it sounds like you took apart the whol engine and put it back together ass backwords.
Old Aug 1, 2007 | 11:09 AM
i mean, it drives fine and everything...are these sensors expensive?
Old Aug 1, 2007 | 11:39 AM
HAVOC's Avatar
Have a look at an EWD (electrical wiring diagram), find out if they share a ground point. You may have a loose ground.
Old Aug 1, 2007 | 12:58 PM
Weasy2k's Avatar
if you had all those codes your truck would not be running...
Have you unplugged the ecu before?
Has anyone worked on the vehicle recently? (removing any major parts of the truck and put it back together)
Personally i would clear the codes and drive around to seee if they all come back then figure things out. WHo said a o2 code was ok? Why would it be ok? Sigh...toyota techs really make me wonder sometimes...
Old Aug 1, 2007 | 01:23 PM
Greedy's Avatar
I second the faulty ground. Check the ground on the drivers side of the intake plenum and make sure it is tight.
Old Aug 1, 2007 | 06:49 PM
well....basically the 02 sensor and cel light was "fixed" by toyota, when they replaced both cat converters (cal spec truck), it came back on about 10 miles down the road, cel light did, and it was 02 sensor...so yea....
i cleared the codes....drove about 50 miles tonight....no light
4wheelparts just installed a new front left cv axle...could that have done it? it was on before they touched it though....
im thinking im ok for now...?
Old Aug 1, 2007 | 06:53 PM
Weasy2k's Avatar
I will never rule out ecu...who knows if the thing will flip out and send codes...the fact that they replaced the o2 sensor and the code came back with everything being ok just means the ecu itself is faulty...everything may be running fine but the ecu just may not realize its outputting all those codes...just drive around and when the light comes back (if) check it again to see what it is.
Old Aug 1, 2007 | 09:40 PM
sounds good, preciate the help. im wondering what toyota did to my ecu when they installed the 7th injector kit...maybe they did nothing but good things
Old Aug 1, 2007 | 11:22 PM
Weasy2k's Avatar
who knows what could have happened mark/midiwall is going through a worse problem with his ecu (well i think it is) messing up on him.
jasonty
41
Dec 23, 2018 01:00 PM
raptor510
Feb 17, 2017 07:11 AM
nonstop
Jul 24, 2015 06:29 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
smiley52
Jul 11, 2015 05:16 AM
