PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. rear disc set up
  2. Advice OBDII code reader - New info? since 2006?
  3. Engine Ticking / Knocking
  4. How do I Produce ABS Blink Codes
  5. need help with dash trim on 96 taco
  6. Annoying Chirp - Squeak
  7. salvage yards in sd
  8. 02 sensor not staying in connector
  9. rear axle seal
  10. front end popping sound when turning
  11. Which Hawk pads are the best??
  12. Do I need to bench bleed or fill a caliper?
  13. What color caliper paint for my truck?
  14. Shock Absorber advice needed
  15. fluctuating idle & hesitation
  16. need source for 1 small part for a cup holder mod.
  17. torque converter lock up switch
  18. Were do you buy Toyota Red
  19. Advice re Potential Purchase
  20. Brake caliper questions 004runner, I searched
  21. MAF compatibility
  22. U-Joints gone?
  23. Need some help with a rattling noise
  24. PS leak, and funky tranny?
  25. 2.7 tacoma problems
  26. Brembo Rotor Part Number
  27. On board CO2 Tanks
  28. power increases
  29. Writeup - Installing Yaesu FT-7800R Ham Radio in '02 4Runner
  30. Help needed fast: CD player install
  31. Rack & Pinion (replacement)
  32. Infiltrator is BACK!!!!
  33. Tacoma seats fit into 4runner?
  34. Leaking front diff
  35. Coolant leak on 3.4
  36. Lifting my 99 4runner
  37. UOA for Supercharged 5VZFE
  38. Popping into neutral.
  39. Wheeler's steering rack bushing
  40. oil leak
  41. Ahhh...Stripped wheel studs!!!!!
  42. ?98 failed 15mph not 25mph smog, CA
  43. Food for Thought
  44. Look what I found in my blower
  45. Did I overfill my trans? (yep I feel pretty dumb...)
  46. 4Runner is goin bye bye soon
  47. HID group buy: Who's interested
  48. TRD Supercharger Question?
  49. roof rack plus
  50. Suspension for Patagonian Dirt Roads
  51. Wow! Thats depressing. 4runners not selling?
  52. How to Remove '02 Rear Bumper Plastic
  53. front seat replacements
  54. Just completed my Stubbs slider project...Dial-up beware
  55. Tire/Speedo reading
  56. Bumper Swap
  57. Do 3rd Gens have a fuel shutoff switch?
  58. 2002 16" 5-Spoke High Gloss Wheels
  59. Washed the 4Runner Today...Pics..
  60. proper vacuum pressure for FPR
  61. Amsoil
  62. Picture/info request, rear bumpers
  63. timing belt replacement?
  64. bumpers front and rear
  65. which air filter?
  66. I need grille/rocker panel help!
  67. damaged door seal
  68. 4runner Hoods Swappable? Going crazy.
  69. Rear Differential, Pinion Nut, Oil Seal, Crush Sleeve
  70. changing shocks based on mileage
  71. My Rig is Getting There (Thanks to this forum!!!)
  72. New suspension, new noise
  73. Need help with my 4runner
  74. Is it just me or are the 5 Star rims hard to balance?
  75. Life after a Fabtech lift
  76. How do I repaint "limited" plastic cladding.
  77. 22.5 MPG achieved !!!!!
  78. 02 auto tranny question
  79. Bake Master Cylinder - New or Rebuild? 00 4runner
  80. 3rd alignment in 9 months!!!
  81. Question on cats and Toyota warranty
  82. Hood not shutting properly...
  83. where do you hook your acc power at?
  84. tires and possibly wheels...
  85. 1996 4run Whining Noise while driving
  86. Picture request: sliders and lengths
  87. How to adjust ebrake cable?
  88. 4 runner resale values tank!! Wow....I'm baffled
  89. Anyone installed a brake controller in a 3rd gen 4runner?
  90. Ooooooooooooooooooooo
  91. Meguiar's Trim Detailer for our faded flares
  92. Optima battery in a 2002 Tacoma
  93. My ride and rack
  94. Have to let her go.....
  95. Changing your belts
  96. ? about 3in suspention lift
  97. Repaint - Looking for pic of pearl white
  98. Fuel Shutoff Crash Protection?
  99. Transmission rebuild price check
  100. Help - brakes are very touchy
  101. AC is how much
  102. Simple Brake Questions 00 4runner
  103. Cheap 4runner parts. WHERE???
  104. middle headrest?
  105. Rear Axle noise.
  106. Tundra upgrade, now no brakes.
  107. Towing questions...
  108. exhaust size
  109. 99 runner fold down rear seat question
  110. ~ My 98 RUNNER ~
  111. Keep An Eye On Your SPARES!!!!
  112. Do you guys cross-rotate?
  113. '96 SR5...anyone had THIS starter problem?
  114. Time to show off the new toys
  115. Just painted my sport wheels!!
  116. dash problem
  117. Diff drop question
  118. '96 3RZ-FE cracked head--looking for repair info
  119. Your MUST HAVE Tools for Travel
  120. Rear axle seals and new drums now shakes when braking.
  121. 97runner front differential replacement?
  122. Thoroughly impressed with deckplate + isr mod
  123. Body Lift Install...?
  124. Has anyone ever painted sport wheels?
  125. toy tec 3in ome lift for 2wd?
  126. check out my new tires and rear bumper
  127. 3rd Gen Bumper Replacement
  128. Help fixing oxidized headlights
  129. A/C & Speedometer Failure : Need Help
  130. Transmission overdrive problem
  131. Exhaust questions.
  132. Time to upgrade my HID projectors...again
  133. Rim question
  134. Help Loosing Coolant 00 4runner - stuck north
  135. 2000 SR5 2WD runner
  136. 96-2002 4runner L.E.D. License Plate Light questions?
  137. CEL after adding STP cleaner. What gives?
  138. 2.7L IAC valve question
  139. Verify Fuel Tank Size in '99
  140. Finally leveled the 4Runner - OME 882's installed
  141. How often should you replace your Spark Plug and Wire?
  142. Will 2002 Taco Headlights Bolt on to a 2000
  143. How do you tell if the Timing Belt and Water Pump has been replaced?
  144. ADD Solenoid Question
  145. Finally pics of new tires and painted rims
  146. Quick Fog Light Help.
  147. 3rd gen front speaker and sound system upgrade
  148. 2 quick headlight questions....99 runner
  149. would this help bring my back end up?
  150. Steering Wheel Replacement
  151. Removing 5vzfe
  152. 96 stock suspention spacing
  153. Key won't come out, what's this part??
  154. My new truck!
  155. Swap an oem E-Locker into an '02 Sport - Possible??
  156. How much/heavy can Gen3 load up into cabin?
  157. 3.4L dyno test results from a Prado
  158. 01-02 sport hood parts
  159. stock tire size
  160. 3.90's with 285's?
  161. Question regarding worn spark plug
  162. Anyone know where I can get a rear windshield window?
  163. California Spec 4Runner (Live in VA)
  164. Replacing Shocks & Struts
  165. would these tires work
  166. crack head smashed my window. Who makes a good alarm?
  167. 99 4runner muffler cutout?
  168. Brake Problems - Tundra Calipers on 4Runner
  169. JDM Style Vent Shades
  170. A few Undercoating questions
  171. Used BG 44K and instant CEL
  172. Headlights
  173. Can i Re-pin 3.0 wires into 3.4 ECU?
  174. Transmission? Slipping/Shifting/Hesitation at High Rpms
  175. Crankshaft Pulley Seperated
  176. tranny issues??
  177. Running rich
  178. Tranny wizards please
  179. 2wd rear diff locker
  180. Removing 5vz-fe head
  181. tranny gauge mount
  182. Not expecting this during a tune up...
  183. Some important info on aftermarket axles (Superior)
  184. Acceleration noise sounds like.....
  185. Double Din to Din stereo install??
  186. A/C Condenser Drain Tube?
  187. 3rd gen hatch lift
  188. 6 cyl missfire (a little long)
  189. Radiator fluid
  190. what do you think of this plan
  191. Total Chaos vs. Donahoe Racing
  192. Just got S/C on ebay.I have questions.Help
  193. Is my new baby a highlander?
  194. $50 and $150 Emergency/Essential Gear List
  195. Black Pearl Emblems
  196. Murdered-Out Emblems & Hella 500s (Pics)
  197. New amp/ HU/ speakers, now questions
  198. Headers fitment with body lift?
  199. supercharger oil
  200. Calling all TOYOTA ECU experts
  201. Help with my supercharger boost gauge?
  202. 5VZFE MAF Questions - Check Engine Light :(
  203. **My Horn Starts My Car - HELP ME
  204. Need help getting badly breaking injector spacers/grommets out
  205. Sell step bars...replace with sliders??
  206. timing belt/water pump help- WA State
  207. Where Oh where is my EGR Valve? '97-3.4L
  208. ISR for 2.7?
  209. Flushing Brakes - ABS?
  210. Help with 00 4Runner
  211. In hunt for new wheels/tires- need hulp!
  212. Recommendations for cold air intake?
  213. 5vzfe leaky valve covers fixed (56k beware)
  214. DID you Know...oil Cooler
  215. Sporticus is going "under the wrench"
  216. Thank God for JBWeld - Rear Diff Case Leak--Now What?
  217. Brake light ( stop light ) problem
  218. New tires..w/pics
  219. 01 Tacoma V6 slips out of 5th gear
  220. Please help..P1135
  221. To Herculine or not to Herculine???
  222. Gulf States Alarm???????
  223. What is missing?
  224. Tranny and 285/75 SSR???
  225. New Rear End Or Rebuild?
  226. winch with stock bumper
  227. Fuel System upgrade for S/C 2002 Tacoma 3.4L 6" lift, 35" tires??
  228. Mystery 7 chemical injection/ engine cleaning pc cpntrolled service?
  229. Need as much help as possible with a bio-diesel conversion
  230. Best headllamp for a 99 runner?
  231. 97 cruise control
  232. Getting a tow and auto tranny damage?
  233. Fuel Gauge issues
  234. Trailing arm skid plates question
  235. Coilovers VS OME -> Cost:Performance
  236. One man brake bleeding....DONE!
  237. will 07 Taco wheels fit on my 03 Taco
  238. o2 sensor trouble
  239. No holes drilled CB Install
  240. ISR mod Messing up?
  241. Mysterious Wet Spot
  242. Pain in the @$$
  243. retrofitting a 01-02 chrome grille on a 99
  244. 5sp Manual Tranny in 99 4run ltd
  245. Locating 96 4runner MAP Sensor
  246. 4wd shifter stuck
  247. Replacement Bumper Cover/Guard - Anyone Know
  248. Sign of an A/C leak? *pic*
  249. OME coils or spacers???
  250. cruise control not working
