U-Joints gone?
Old Aug 6, 2008 | 05:51 AM
Jay204's Avatar
U-Joints gone?
My truck started making this weird sound the other day....it sounds like something is rubbing....and it starts to squeek when the vehicle starts to move forward. I believe its my u-joints on the rear shaft are gone...anyone ever had this same problem ?
Old Aug 6, 2008 | 05:58 AM
dirtoyboy's Avatar
errrr uhhh whens the last time you serviced the joints?
They should be serviced at every oil change MINIMUM....
A lot more if you go off road
Old Aug 6, 2008 | 06:02 AM
Jay204's Avatar
By service? What do you mean ? Cause there are no grease-nipples....so I can't really maintenance them. They have never been done since I owned the truck. "2years"
Old Aug 6, 2008 | 06:06 AM
TopRunner's Avatar
oouch!
You are going to have to look a little harder. I think there is a total of 8 fittings on a 4x4 runner. 2 years without grease is not a good thing.
Old Aug 6, 2008 | 06:09 AM
Jay204's Avatar
Originally Posted by TopRunner
oouch!
I'm only doing the rear shaft...talked to Toyota today..only 2 on the rear drive-shaft. And how can I grease an enclosed U-joint? I'm getting aftermarket new one's with grease nipples......
Old Aug 6, 2008 | 08:31 AM
Jay204's Avatar
So no one has any idea's about this winding sound.......
Old Aug 6, 2008 | 08:35 AM
wjwerdna's Avatar
replace your u-joints... there is a grease fitting reachable by turning u-joint until you can see it/get to it kind of inside it
Old Aug 6, 2008 | 08:39 AM
chad99's Avatar
from what i remember 2wd = no nipples, 4wd = nipples
Old Aug 6, 2008 | 08:40 AM
Maj's Avatar
Maj
A dry joint will emit a high-pitched squeaking sound for each revolution of the driveshaft. Not unlike a squeaky toy for a pet. The sound will typically begin once the vehicle is moving and continue up till around 20 mph. The good news is that bad joints usually go thousands of miles before they fail. Vibration can become an issue.
Old Aug 6, 2008 | 08:43 AM
Jay204's Avatar
Weird thing is...my friends 99 taco has nipples...where my 2000 4Runner doesn't...so no idea there both 4x4
Old Aug 6, 2008 | 08:44 AM
Jay204's Avatar
Originally Posted by Maj
A dry joint will emit a high-pitched squeaking sound for each revolution of the driveshaft. Not unlike a squeaky toy for a pet. The sound will typically begin once the vehicle is moving and continue up till around 20 miles per hour. The good news is that bad joints usually go thousands of miles before they fail. Vibration can become an issue.
That about sum's it up. Thank a lot!!
kawazx636
Oct 6, 2021 03:03 PM
Odin
Sep 24, 2015 04:38 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
AppalachianOffRoader
Aug 12, 2015 12:55 PM
ayoung101
9
Jun 30, 2005 06:10 AM
