ISR mod Messing up?
Old Jul 13, 2008 | 03:22 PM
Atticus_6147's Avatar
ISR mod Messing up?
Hey everyone, I just did the ISR mod and now when I turn on my 4runner it will idle at 1200 RPMs when it use to be at 900. I pulled the fuse(EFI) also. My question is is this suppose to happen? ALso, I pulled the fuse with the engine off, should I pull it with the engine on? Thanks in advance and please let me know because I don't really want to drive her until she's running right again.
P.S. I love the sound she makes now!
Old Jul 13, 2008 | 03:32 PM
flatland4runner's Avatar
possible leak in your vacuum lines, at the connections?
Old Jul 13, 2008 | 04:16 PM
mikes19984x4's Avatar
i've done the isr mod to my 3.4 also, and whenever i crank it up no matter the temp outside, it seems to idle around the 1100-1200 rpm mark for about 2 or 3 minutes, and once i start driving, it drops off to around 800 rpm. and i'm quite sure i don't have any vaccum leaks and i also pulled the fuse like you say you have done...and that sound you say you love so much from the isr mod is the sound of your right foot draining your gas tank, as i first found out...
Old Jul 13, 2008 | 04:21 PM
LuminoZ's Avatar
They all do that when the engine is cold. Higher idle when cold is normal.
Old Jul 13, 2008 | 04:53 PM
You guys are right and thanks for the help. I jumped the gun on this one but thanks once again for the advice.
Old Jul 13, 2008 | 05:12 PM
blueyoda's Avatar
Ha, the first time I started my runner I thought I had bought a lemon. The thing reved up to 1300 and didn't move. The PO told me it was normal but I was a little sceptical.
Old Jul 13, 2008 | 05:24 PM
scuba's Avatar
Hmm, Not to sure about pulling the efi fuse while its running, But tell you the truth i wouldn't try it
Old Jul 14, 2008 | 03:01 PM
4x4phil's Avatar
Ya I thought my truck ran wierd when I first got it, beacuse it stays in warm up mode for longer then my older Toyotas
TheBFA
Feb 15, 2020 06:55 AM
ktm192k
Oct 1, 2015 08:47 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
EVars
Sep 29, 2015 02:06 PM
oldblue
Sep 28, 2015 04:07 PM
