99 runner fold down rear seat question
Old Jul 28, 2008 | 07:23 AM
sharrack's Avatar
I enjoy removing the lower seat pads for more storage on long trips so how hard is it to convert the folding seat section to make it removable?
Cut the rear carpet under the protective pad but are the 2 sections connected at the center hinge point?
Can the left and right side come out separately?
Thanks for your help, Kenny S>
Old Jul 28, 2008 | 07:31 AM
Rock Slide's Avatar
I dunno how you're removing the lower rear seat pads currently, but if you do it often, you ought to invest in a set of these . Has made the the process of removing them much more convenient:
Have not needed to remove the rear seat backs, so I can't help you there.
Old Jul 28, 2008 | 08:38 AM
michalik_piotr's Avatar
rock, post a link to where to get those? thanks..... i know i've seen em somewhere but forget where....sonoran or rock crawler...
Old Jul 28, 2008 | 09:39 AM
Jerm's Avatar
http://www.sonoransteel.com/store_wing_bolts.html . Looked into those myself.
Old Jul 28, 2008 | 10:12 AM
Rock Slide's Avatar
Originally Posted by Jerm
That be them. They work great too.
For those looking for a cheaper alternative, check out Bob's wing bolts: http://4runners.org/writeups/seatbolts/index.html
Just remember, in most of pictures on both Steve's & Bob's site, the wing bolts are shown mounted with the trim covers on too.
Bob's pic:
However, you will actually have to add a bolt to hold down the trim covers as seen in this pic from Steve's site. Reason being, the bottom tab of the cover no longer exists after the hole is drilled for the wing bolt. (Personally, I just left the covers off, but some may want to retain these trim covers):
Old Jul 29, 2008 | 04:03 PM
Ron Helmuth's Avatar
thanks for the lesser expensive alternative.
GreenLion
Jun 7, 2021 10:49 AM
4x4-runner
Feb 26, 2017 06:42 AM
warrenjcarlson
Jul 22, 2016 11:47 AM
cchinny
Jun 25, 2015 08:11 PM
NerfHerder-97SR5-
11
Jun 13, 2002 10:56 PM
