PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. 99 4Runner shakes when taking off in 1st Gear and Reverse- Suggestions?
  2. Best 96-98 Front Bumper Lights
  3. Moldy Smell Cabin Air Filter / AC Evaporator Service
  4. 3rz lift points
  5. 98 4runner cylinder 4 misfire
  6. trans swap info/help
  7. First 3rd gen 4runner/first post in this section
  8. Shorty Antenna ?
  9. Reversed Antenna Motor & Wiring OK?
  10. Would buy a rig with replaced frame?
  11. Pulls left not alignment
  12. Are the 3rd gen 4runners and 1st gen tacomas parts interchangable??
  13. viper 5701 alarm install help?
  14. Are 4runner axle housings the same from 96-02?
  15. help pleaseee im new! 3.0td surf 1996 sputters and coughs on acceleration
  16. Tie rods ends/outers
  17. Timing
  18. 94 4Runner Jack and tools to lower a spare on a 96 4runner
  19. 99 4runner won't start
  20. What is leaking? 2001 4runner Question
  21. Elocker vs traction control or something??
  22. What is wrong with my brakes?
  23. *Help* Suspension Q's - 2002 4Runner SR5
  24. Want Sequoia / Tundra Wheels
  25. 96 Tacoma rear suspension
  26. Parts interchangeability? 97 4Runner with 02 4Runner
  27. Do the 89-94 leaf springs fit on the '01 tacoma?
  28. Airbag Light On
  29. Should all new brake drums have balance weights?
  30. Need some tips on changing struts on my 99 runner
  31. Have a lift idea but not sure for Tacoma
  32. 98 tacoma 4x4 shaking/stuttering when taking off
  33. Help please- Bilstein 1525 lower bushings don't fit my 4runner.
  34. 01 tacoma auto tranny help
  35. Does your Horn Sound Weak?
  36. When to Replace Plug Wires and Fuel Filter?
  37. VIP Key FOB vs regular?
  38. 2001 Toyota 4Runner Sport help with e locker
  39. coil packs on the valve cover?
  40. Braking Issue with 04 tacoma on 33's
  41. Looking for these flares in picture for 2000 4 Runner
  42. Real bumper
  43. rear diff problems, due to broken driveshaft
  44. Multimode TC problem (VF3AM)
  45. Water pump tick/chirp
  46. 95.5 locker
  47. New SC'd 98 4Runner and AMSOIL Recommendations
  48. FSM for 3rd Gen 4Runner?
  49. 97 Tacoma value
  50. 98 4runner fuel leak
  51. 3.4 rebuild
  52. Fuel leaking like a sieve
  53. Transmission filter kit
  54. custom front bumper
  55. turn signal noises
  56. do you have a 2001 tacoma 3rz?
  57. Interesting Failure.
  58. Power Window Issues
  59. 98 4Runner rear brake issue?
  60. tacoma tranny or clutch problem
  61. Replace Starter
  62. Hood Release Cable Loose
  63. 3RZ hot start idle issues
  64. Rear end leaking.
  65. Ecu question 03-04 Tacoma
  66. 5VZ-FE blower resistor part number?
  67. Buying a 4Runner, do you think this is a good deal?
  68. Decisions Decisions
  69. 1998 tacoma pre runner engine knock
  70. 99 Runner -thump in the drivetrain
  71. Charge circuit guru's...
  72. 4runner rear sag
  73. Elocker carrier bearing that's different. What's the part number?
  74. Anyone know who's 4runner this is?
  75. front end shake
  76. First Toyota!!
  77. Master window switch swap questions
  78. OEM Gold 4WD Emblem?
  79. Shock, struts, sway bars and seats.... Can this thing be anymore uncomfortable?
  80. Strong pull right while braking
  81. 96 4runner stock hitch install issues
  82. Bush bars?
  83. fuel injector issues again
  84. Steering rack replacement hydraulic connection issue
  85. 99 runner What are the strut/ shock of choice these days?
  86. Rear Locker won't engage
  87. Which Clutch Pedal Spring?
  88. Need a built transmission for towing
  89. Broken ignition/steering lock cam
  90. Starting Issue - Won't turn over unless I cycle the headlights
  91. my new 40 inch led bar.freaking epic
  92. No lift tire questions for 04 Taco
  93. 1999 Tacoma 3.4L no power.
  94. 2004 Leaf Spring
  95. cracked driver side shock tower advice
  96. Intermittent No-Start
  97. 99 4runner rear 2" lift coil suggestions?
  98. Round Two...'02 Sport Edition
  99. Drum Brake Removal/Star Adjuster help 01 Taco 4wd 2.7
  100. 96 4runner SR5
  101. Maintenance questions for 1997 2.7 Tacoma
  102. Part # for 1998 Key Fob?
  103. 98 3.4L 4 Runner wont rev over 3500 - Detailed!!
  104. 2.7L Knocking Noise at StartUp - Only in D or R
  105. Can I buy these small parts from toyota?
  106. Best Air Intake for Gas Mileage
  107. Can I use this to replace my factory rails?
  108. Is it possble to make 96-98 tranny work in 99 4runner?
  109. Original 244,000 mile o2 sensors shot
  110. Toyota Tacoma first generation rear axle assembly
  111. driveshaft interchangeable part from 4runner to a tacoma?????????
  112. New front pads - strange groan noise
  113. Help on interior lights
  114. Intake Air Connector on 2.7 Tacoma
  115. No pressure on clutch pedal
  116. Replacing oil filter bracket on '97 2.7 Tacoma
  117. slow rear end sway at highway speeds
  118. Lubing my Tacoma
  119. 3rd Gen 4Runner Bumper brand selection help
  120. B&M 70264 Transmission Cooler Install
  121. wierd engine noise
  122. 1999 Tacoma Heat issues
  123. 04 tacoma sputtering and running very rough
  124. Picked up a great beater!
  125. Front Driveline Noise
  126. w59 input shaft replacement ?
  127. 2001 Toyota Tacoma v-6 3.4 180 Degree Camshaft Marks
  128. Spark Plug Cables Shocking
  129. 96 4runner ac plus tps problems
  130. knock sensor location
  131. Antenna Stuck Making Loud Noise
  132. Reese or Draw Tite Trailer Receiver?
  133. Best Trailer Setup?
  134. Slow Throttle Response, Fuel Mileage Low, Backfire When Shifting etc..
  135. Over active traction control
  136. High Mileage '01 Pricing??
  137. water pump change out seal packing?
  138. A short swim thru a flood
  139. Help with 4runner head gasket replacement!
  140. 99 4Runner starting and running issues
  141. 1997 4runner muddy(brown) clutch fluid
  142. More legroom
  143. How is your cruise control hooked up under the hood?
  144. 300,000 Mile Club
  145. 550cc supra injectors for 5vz-fe
  146. Will 2006 struts fit on a 95.5 Tacoma?
  147. Overheating in Summer, No FRONT heat AT ALL
  148. May sell....
  149. 2.4 cold start issue
  150. passenger side window does not work with master switch
  151. Driver Power Window Not Working; switch and motor seem fine
  152. 3rd gen 4runner won't start. Help!
  153. Rear window problems!!
  154. finally getting a 4runner - a radiator question
  155. Belt & Hose change time. Hose clamps ?
  156. Advice on removing IAC valve without stripping screws
  157. 1'st gen graphics on 3'rd gen 4Runner
  158. 01 4Runner w/ Low Compression
  159. P0135 and P0141 codes after 3.4 swap
  160. Selling the 87 4runner need advice on a 3rd Gen 4runner
  161. Crazy electrical issue
  162. Sealing the screws on the factory rack?
  163. Help with possible blown head gasket
  164. Technical question about transmission kick down cable and using 04 trans in an 02
  165. 3RD gen purchasing advise (kinda newbie)
  166. stall converter a340e (3vz) vs a340f (5vz)
  167. Introducing my self first time toyota owner need a little advice info
  168. 98 Tacoma SCORE!
  169. new to me '97 runner, questions
  170. 95 Tacoma 2.7 blown head gasket orrr ?
  171. I need help please!!! Engine miss.
  172. Help what is this switch 95 tacoma
  173. Vacuum lines blocked off on the TB???
  174. Replacing rear output bearing in T-case?
  175. NO NO Ball Joints
  176. 95 tacoma 2.7 a/c kit
  177. stutter at idle, engine dies after throttle blip
  178. 1999 V6 Power loss/miss in low RPM ~Assistance Request
  179. 1996 Toyota 4runner Limited Oil drain plug Size
  180. Any Brake Pro's? PLEASE HELP!!
  181. Suspension Update Advice Needed
  182. PO1135 (see manual)
  183. 02 4Runner - Buzzing noise coming from throttle body
  184. Big dogs in your 4Runner
  185. Body lift Sacramento Valley
  186. My 4runner 1999 SR5 doesn't have a roof rack
  187. 98 Limited Runner - Drivetrain issue - Need help
  188. 96 4runner reversed polarity
  189. 98 limited wont start!
  190. Looking at a 97 4runner, how many miles?
  191. Annoying Engine Squeak
  192. 6sped tranny?
  193. Swap a 2.7L 3RZ-FE for a 4.0L 1GR-FE
  194. Stupid POS alarm system needs total diablement
  195. PO441 and PO446
  196. 96 4runner soft brake pedal
  197. 4runner overheating
  198. Need help on lift kits 4runner 3rd gen SR5
  199. Misfiring and momentary hesitations while driving
  200. 00 yota prerunner e lock question
  201. Installing trailer brake - help!
  202. 97' Taco Front Clip Upgrade!!
  203. 2000 4Runner Upper Ball Joints R&R?
  204. Engine Wiring HELP - Wires came out Connector
  205. 97 4Runner fuel injection issue-bad gas??
  206. help! 95 Toyota Tacoma v6 3.4l 4wd automatic transmission
  207. New-to-me 1998 4Runner - couple questions
  208. 96 4runner airbox noise?
  209. 00 prerunner ac fan question
  210. 98 4runner leveling kit question
  211. Snap On Tensioner Tool YA9730 for Timing Belt Replacement
  212. T-case Removal....
  213. Obdii br-3?
  214. 96 4runner bad control arm bushings
  215. Cold air intake and inner fenders 2001 Taco
  216. 96 tacoma 2.7 running rough and sputtering
  217. Rough idle in cold start, possible leaking injector???
  218. How close 1994 4runner frame to 1998 4runner
  219. 98 4runner keyless entry
  220. Does your 3.4 auto do this? Wierd cruising rpm's
  221. 96 4Runner brake failure
  222. My 1998 4Runner Nightmare
  223. Light Bar in Grille
  224. 2.7 L Cylinder 3 Miss Fire 97 4Runner
  225. Doing TB & WP, how to install lower tensioner & Pulley
  226. Wheel Question
  227. Stock vs. Current vs. New Suspension options
  228. 1998 Toyota Tacoma 2WD => Add-on air conditioning and bigger wheels?
  229. Throttle lag before operating temperature
  230. 1st Gen Taco, evap canister questions...
  231. 2001 Tacoma 4WD not engaging?! HELP!
  232. grease in rear passenger drum
  233. Frame Dimensins??
  234. downsize tires on '98 Tacoma
  235. 2.7l tacoma performance questions
  236. blown 3.4l swap
  237. 97 taco 4x4 tranny. 150f? 151f? rebuild kits
  238. Upgrade SS1.2 rear help
  239. 2001 4runner rear axle swap questions.
  240. Strange engine issue
  241. White smoke from Tailpipe
  242. 2000 SR5, brake shudder, strange problem.
  243. 96 tacoma 4wd issue
  244. Airbag Light?
  245. Rear axle housing flange question
  246. 3.4 v6 5vz-fe high idle
  247. Front Brake Problems 98 Toy 4 Runner
  248. 3rd brake light problem
  249. Gear Install - Pattern Check
  250. Slip indicator light help!!
