2001 4runner rear axle swap questions.
Old 06-11-2014, 03:23 PM
Rob2thec's Avatar
I have searched, Google and many other forums so thank you for your replies in advance.
I have a 2001 4runner SR5, 4x4 3.4L
My plan for this vehicle is to swap a Deaver 62 inch rear leaf pack into the rear and a total chaos front long travel kit. I do mainly desert chasing and pre-running for a friends race truck.
My questions:
With the stupid VSC and ABS in this years 3rd gen IF I was to use a tundra, T100, or tacoma rear axle in place of the 4-runner axle what issues would I run into? I would love to remove all of the above systems but I am not sure what electrical and wiring issues would become of the removal. I am aware of the work arounds for these systems (VSC ABS) but if I remove the axle with the sensors what could happen?
Also what is the distance between Wheel mounting surface for the front of the 3rd gen 4runners with IFS? I dont want to use a T100 axle if it is going to be wider then a long travel kit.
What other Toyota axles would be close to the width of a long travel front 3rd gen 4runner? I would like to avoid spacers if all possible.
The reason for replacing the axle is that I can buy a used housing, have it trussed, re-geared, retrofit an e-locker, and have the whole thing powder coated. This will allow me to build it over some time.
I am set on losing the 4link thing that these have. I have already done all of my research on that.
Thank you guys so much for all of your technical info!
-R
Old 06-11-2014, 06:25 PM
habanero's Avatar
I am not much help other than to say you will lose your speedo when you ditch the abs *but* installing and wiring up a VSS is an easy job.
Consider this a bump to get some real answers to your questions.
Old 06-12-2014, 08:03 AM
Rob2thec's Avatar
Thank you Habanero. What is a VSS exactly?
Anyone else?
Old 06-18-2014, 02:02 PM
Rob2thec's Avatar
OR maybe someone can tell me what year Tacoma rear end would have the ABS that I could use?
Any and ALL help would be greatly appreciated.
-R
Old 06-18-2014, 02:08 PM
habanero's Avatar
Vehicle Speed Sensor. At the back of the transfer case by the output shaft. In my 96 there was a plug. Mightymouse found one for me, a little wiring and tada! Pics nearer the end of my build thread.
The rest of that I still am no good for so bumpity.
Hatch man
08-25-2021 12:54 PM
6th Gear
19
12-10-2019 07:31 AM
DanStew
06-29-2015 10:46 AM
Ott47
06-26-2015 05:21 PM
Niameyrider
06-25-2015 05:50 AM
Quick Reply: 2001 4runner rear axle swap questions.
