VIP Key FOB vs regular?
Old Oct 10, 2014 | 08:35 AM
IDM's Avatar
IDM
I have a 98 and trying to find the right key fob for it.
I read an old thread that mentioned a VIP version.
How can I tell if I have the VIP alarm system?
How can I determine what FCCID I need for my 98?
Thanks!
Old Oct 13, 2014 | 02:44 PM
IDM's Avatar
IDM
guys, seems to be a lot of confusion on this topic. Cant believe there isn't a thread yet with part numbers and fcc id for the different year fobs. Once I get the correct 98 fob I will post the info.
Old Oct 13, 2014 | 03:15 PM
TheDurk's Avatar
'98 was a changeover year, so there is a lot of conflicting info, all of which may be correct depending on whether early or late month, factory or port/dealer installed, alarm or not. This is why I don't answer. I can't be sure. Don't expect one fob fits all.
Old Oct 15, 2014 | 11:15 AM
IDM's Avatar
IDM
okay I understand.
I have a 98 built in February with a stock alarm system by the way
Old Oct 15, 2014 | 09:19 PM
TheDurk's Avatar
okay I understand.
Well, I'm no expert but that one should be easy. The only alarm system in 1998 was the dealer/port installed RS3000 and that was a grey 2-button remote in 1998 with FCC ID - BAB237131-022. There were black ones and grey ones. They are identical in apperance other than the case color. The black one is 08191-00870 and the grey is 08191-00871, discontinued and replaced by PT398-07101. The grey one will not work on 1997 and prior vehicles, only 1998..
http://www.keyless-remotes.com/servl...-Remote/Detail
There are aftermarket equivalents around like this:
http://www.ebay.com/itm/New-Toyota-R...-/310834956365
Try putting your VIN in here to confirm: http://www.toyotapartszone.com/oem/t...191-00871.html
Old Oct 16, 2014 | 09:40 AM
IDM's Avatar
IDM
Thanks a lot for the help! so on a 98 the good looking and more modern fob used in say a 2002 wont work on my car ehh?
Old Oct 16, 2014 | 08:52 PM
TheDurk's Avatar
Nope. That's the factory system that was introduced MY1999. Different FCC number. '99+ only except maybe some late in the year '98's. But not if you have the RS3000 alarm system.
Old Oct 17, 2014 | 12:43 PM
IDM's Avatar
IDM
okay well I just ordered 89742-35050 fcc id hyq12bbx from the Toyota dealership. The parts guy told me this was the correct one for my 98 and this remote supersedes the old one now. I will have to see if it works!
Old Oct 17, 2014 | 04:55 PM
TheDurk's Avatar
That's cool. Sorry, I didn't think you were late enough in '98 to get the '99+ system. Confirm you're good with your VIN here:
http://www.toyotapartszone.com/oem/t...742-35020.html
Where it says "TIP".
I should have kept my mouth shut (fingers quiet).
Old Oct 27, 2014 | 09:55 AM
IDM's Avatar
IDM
You were correct this is the part # for my 98 PT398-07101
It just looks a little newer than what was pictured above.
The issue Im having is that either button on the remote can lock or unlock the car.
Maybe I programmed it wrong but it's super weird. And also it doesn't beep when it's locked. Perhaps I programmed it wrong but I have no idea when the car is locked or unlocked with this remote. I don't believe this is how it would be setup from the factory, would be surprising.
Old Oct 29, 2014 | 09:56 AM
IDM's Avatar
IDM
Is it normal that either button on the remote can lock or unlock the car?
Also I sometimes hear a beep and other times not when locking and unlocking.
Thanks again!
83yotastockR
11
Nov 10, 2015 06:54 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
PNW94Runner
Sep 29, 2015 02:55 PM
Rcbc92
Sep 26, 2015 03:00 PM
