turn signal noises
Old Sep 27, 2014 | 09:04 PM
Flightguy's Avatar
turn signal noises
They aren't the ones you want to hear.
Recently, I can't pinpoint when,my turn signals started messing up. When I turn it on, occasionally, it will make a grinding type of sound. It continues until I turn off the signal,or I jiggle the handle.
It's weird. It's intermittent, but when it starts messing up, it status that way for a few signal attempts.
Old Sep 28, 2014 | 12:55 AM
wyoming9's Avatar
Red face
About the only thing that might make noise would be the flasher or the contacts in the switch..
I can`t really say but it should not be a grinding noise.
Do the turn signals work when this happens??
Does this happen with the vehicle stopped and turn signals on??
Are you sure it is not something else??
Brakes??
Wheel bearings /Steering linkage??
Old Sep 28, 2014 | 06:57 AM
JasonYota's Avatar
Switching to synthetic blinker fluid may help.
Old Sep 28, 2014 | 08:46 AM
wyoming9's Avatar
Red face
The Auto parts store was out of stock awaiting more.
Last I checked a few minutes ago.
Old Sep 28, 2014 | 01:12 PM
TheDurk's Avatar
That stuff causes flash leakage. Stick to regular.
Old Sep 28, 2014 | 02:41 PM
Flightguy's Avatar
Flasher fluid...yeah. I'll bit that next time I'm at home Depot.
The issue occurs regardless of whether I'm moving or sitting still, in park or drive. 100% positive it's related to the flashers. I move the lever, the signals don't begin blinking, but there's a grinding noise from the steering column. It's almost like gears slipping on each other. The sound is like a windup toy when you let it go.
Old Sep 28, 2014 | 03:30 PM
rworegon's Avatar
Can you post up a clip with some audio of it?
Sounds like a relay is having issues.
Old Sep 28, 2014 | 03:42 PM
TheDurk's Avatar
Sounds like the release pawl is FUBAR'ed. The thingy that makes it stop when the turn is done. Time for some surgery and maybe a new turn switch stalk.
Old Sep 28, 2014 | 05:45 PM
Flightguy's Avatar
Deleted
Old Sep 28, 2014 | 05:57 PM
Flightguy's Avatar
All right. I think I've uploaded a zip of the sound it's making. I recorded it as an mp4 on my galaxy. I had to save it as a zip in order to get this type of file loaded onto the site.
File Type: zip
Old Oct 1, 2014 | 05:38 PM
Flightguy's Avatar
Anyone have any ideas with the sound file uploaded?
Old Oct 2, 2014 | 05:24 AM
Jomoka's Avatar
Mine will occasionally do that exact same noise when I don't fully engage the turn signal - when I'm just making a lane change and want to do a couple of flashes I'll push to the point where it starts flashing, but doesn't click into place. If I just *barely* make contact, once in a great while it will buzz like that.
I'm assuming it's the switch making very poor contact, and the flasher relay is only barely getting current, so it just buzzes instead of fully turning on.
So I'd guess if yours is doing that when clicked all the way in that the contacts inside are dirty and worn, not making good conduction. It's probably not worth the effort to try to fix the switch, probably better off getting another one from a junkyard.
Shoua
13
May 22, 2016 05:19 AM
ripp96
Jul 25, 2015 02:32 PM
kvanzandt1
Jul 18, 2015 10:15 AM
razorman8669
Jul 12, 2015 12:13 PM
smiley52
Jul 11, 2015 05:16 AM
