Antenna Stuck Making Loud Noise
Old Aug 22, 2014 | 03:06 PM
IDM's Avatar
IDM
Any time I turn the radio on my antenna makes noise for about 15 seconds in an attempt to go up and down.
There is a headunit in the car and a couple amps so I am not sure what's up with the system.
Is this a common problem? Is it that the motor is stripped? The antenna goes up and down a little but usually stays right in the middle and cant do either.
Thanks a lot for any tips
Old Aug 22, 2014 | 05:42 PM
habanero's Avatar
A lot of times it's the plastic track that breaks. You can hear the motor and the antenna doesn't really move. You can either unplug the motor so you don't have to listen to it every time you turn the key, do something like the Tacoma whip or simply replace the mast and track for about $20ish bucks. If you do replace it pull the motor apart and remove any broken bits before installing the new one.
More info in my build thread, post 2 has table of contents or search antenna motor within thread. Lots of other info around here besides what I've got, too.
start with post 332
https://www.yotatech.com/forums/f200...1/index17.html
You only need to get any track bits out, I tend to dig deeper than I need to out of curiosity. When I regreased I used a plastics safe lithium grease, but there's pretty darned much grease already in there.
PS. Always nice to know year, make, model and that sort of thing when answering questions...
Old Aug 23, 2014 | 08:40 AM
TheDurk's Avatar
Some important info in this thread.
http://www.toyota-4runner.org/3rd-ge...w-issue-2.html
Br careful about which replacement mast you buy. Mine is still working perfectly 2 1/2 years after the fix. I used white lithium grease.
Old Sep 4, 2014 | 06:28 AM
IDM's Avatar
IDM
awesome, it is a 98 4wd v6 non limited
think I'll pull the antenna fuse for now and replace as you guys mentioned eventually.
fountain
Dec 31, 2015 06:08 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
razorman8669
Jul 12, 2015 12:13 PM
cars-guy
Jul 11, 2015 07:51 PM
Poncho0206
Jul 10, 2015 06:21 PM
