wierd engine noise
Old Aug 27, 2014 | 01:36 PM
oddjob1370's Avatar
wierd engine noise
2000 4runner sr5 2wd 3.4l auto.
Got a weird engine noise only in drive like a rattle or pinging. Not at normal throttle only when I get on it. Changed spark plugs and wires thinking it was a bad ping. Still same noise after.
Any ideas on what to check next?
Old Aug 27, 2014 | 01:39 PM
JasonYota's Avatar
Bad gasoline can cause this. How long has it been doing it?
Old Aug 27, 2014 | 01:40 PM
oddjob1370's Avatar
Oh yeah no engine lights and truck idles perfect. Even reving with it in park doesnt make the noise. Only when its in drive. And noise is coming from the front of the truck
Old Aug 27, 2014 | 01:41 PM
oddjob1370's Avatar
Started yesterday
Old Aug 27, 2014 | 01:45 PM
JasonYota's Avatar
Run the tank down and fill up with quality fuel from a well used station.
Did it start after you filled up from a station?
Old Aug 27, 2014 | 03:38 PM
oddjob1370's Avatar
Nope almost down to 1/3 of a tank from full. Filled up last week
But only happens in drive is the odd part
Old Aug 27, 2014 | 05:39 PM
cep89's Avatar
I had a noise like that when I got on it. I was a loose heat shield behind the engine. I bent it a bit with a long pry bar to get it to stop. 99 taco 3.4 w/auto sr5 trd.
Old Aug 28, 2014 | 02:52 AM
aowRS's Avatar
Loose crank pulley?
Andreas
Old Sep 7, 2014 | 01:09 PM
ShouldaWornGloves's Avatar
I have had a couple similar experiences.
The first was with heat shields that had 1 of the tack welds crack. Eventually another tack cracked and I could hear it at idle.
The second was the lower bolts on my fan shroud. They came undone and when I would get on the gas I could hear a strange tink tink tack tack sound. After awhile the noise started to sound like I was about to throw a rod.
Both were easy fixes, but a mystery for awhile.
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
Gamble_STi
Jul 7, 2015 07:54 PM
