Spark Plug Cables Shocking
Old Aug 24, 2014 | 07:06 PM
4Xtruck's Avatar
I recently bought a 1997 2.7 4WD Tacoma. I've been going through it and finding it wasn't taken care of very well (low transmission oil and very low rear differential oil -- I have to get a 12 mm hex to check the front dif). When I touch the cables where they attach to the cap opposite the spark plug (I don't know what it is called, but it isn't a distributor), I get a shock on all 4 cables. The cables look new, but I'm wondering if it would be a good idea to switch them out with NGK cables. They are Autolite Professional Series Premium Spark Plug Wires 5mm silicone suppression cables SAE Class E.
There is a lot to go through in the FSM, but I noticed that the grease needs to be different for the spiders than the rest of the fittings. Is that necessary? Before I read this, I lubed everything with Super Lithium EP Moly Grease. Wouldn't this cover both (Lithium and Molybdenum)?
I'm sure the learning curve from 22RE to Tacoma will take some time. Any suggestions would be appreciated.
Old Aug 25, 2014 | 12:31 AM
wyoming9's Avatar
Red face
Time for New Wires I just run Toyota ones to much trouble with after market ones .
Old Aug 25, 2014 | 08:21 AM
TheDurk's Avatar
Baloney. Lots of us run the NGK TE66's (on the V6) and are very happy. I have 80k on mine.
Old Aug 25, 2014 | 02:03 PM
wyoming9's Avatar
Red face
I can only go by my own luck most times all bad
Then the dealer stocks the wires no one else does so maybe the ease of getting them has influenced my bias
Then I change wires and plugs every spring.
Not to say I would not try other wires.
One of the things with living out of town.
Old Sep 7, 2014 | 01:15 PM
ShouldaWornGloves's Avatar
Definitely time for new wires. The insulation is bad. you should never be able to get shocked from your wires. If your are getting shocked while handling the wires near the distributor cap, it could be a cracked cap.
Old Sep 7, 2014 | 01:17 PM
Opps Yea no cap. disregard.
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
cars-guy
Jul 11, 2015 07:51 PM
