driveshaft interchangeable part from 4runner to a tacoma?????????
Old Sep 1, 2014 | 12:14 PM
tocarunner's Avatar
hi,
i recently broke my rear driveshaft in my 1996 extended cab, 4x4, manual trans, 4 cylinder tacoma (2.7L).
my question is, can i grab a rear driveshaft from a 1996, 4x4, 4 cylinder, manual trans 4runner?
will it just bolt right in?
tacoma rear driveshaft is a two piece with a carrier bearing, and a slip yoke.
Old Sep 1, 2014 | 01:16 PM
scuba's Avatar
No. The 4Runner driveshaft is a 1 piece and is around 20" shorter than a Tacoma 2 piece.
Old Sep 1, 2014 | 08:05 PM
DeathCougar's Avatar
What he said. Good thing is, any X-cab Tacoma uses the same length rear half. The difference in the drivelines is in the front half, so if the front half of yours is OK you can swap the rear half and be good to go.
Old Sep 1, 2014 | 09:41 PM
tocarunner's Avatar
Are you sure about this?
What about the bolt pattern on the diff, are they all the same? Ex: open diff or a electric locker?
Old Sep 3, 2014 | 06:15 PM
Yep, 100% sure.
All the 95-04 Tacomas use the same flange on the diff, regardless of Open or E-locked.
AustinTaco
Aug 22, 2022 10:45 AM
vasinvictor
Jan 20, 2016 12:39 PM
PureTacoma_Tundra
PureTacoma_Tundra
Jun 29, 2015 09:45 AM
Valvoman
Jun 28, 2015 02:45 PM
TheManOutside
Jun 18, 2015 03:32 PM
