97 4Runner fuel injection issue-bad gas??
Old Jul 5, 2014 | 09:23 PM
Master_of_4Runner's Avatar
Hi guys, have a 1997 4Runner 3.4L V6. Two weeks ago I completed a cross country trip but while in New Mexico I filled up with 85 octane a few times. (I usually put in 87 octane.) Then a few tanks of gas later my engine threw a cylinder 3 misfire code. Checked the sparkplug/coil and all is good on that front.
Since then, the engine idles rough (it's vibrating hard not revving up), poor fuel mpg, noticeable lack of power when accelerating. It drives "rough". However all of these problems start and stop seemingly almost like every other day and they either all appear together or none of them do. Comes and goes.
Is it possible/probable that that 85 octane gas clogged up the cylinder 3 injector?? Now it needs to be replaced? I poured some injector cleaner in the tank but it has not stopped the problem from reappearing.
Thanks!
Old Jul 6, 2014 | 12:01 AM
wyoming9's Avatar
Red face
Just how does it come and go completely random??
Is it fine at starting but gets worse after a few miles.
If it was me the first thing would be to change the fuel filter.
When was the last time it was done??
If dirt got through the filter it would more then likely have effected more then just one injector.
Old Jul 6, 2014 | 06:48 AM
"Is it fine at starting but gets worse after a few miles."
Yep, that happens
Old Jul 16, 2014 | 01:10 PM
roland750's Avatar
You have a fuel injector that has failed. Mostly likely you also have P3XX code. Do a quick search and you'll see this issue is pretty common on 96-98 5VZ.
steve miller
Oct 10, 2015 01:40 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Cplmike
Jul 8, 2015 08:47 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
