Does your Horn Sound Weak?
Old Oct 10, 2014 | 09:08 AM
IDM's Avatar
IDM
I am embarrassed to use my horn.
It sounds like it's from a 2 cylinder camry that was totaled.
Is it typical that the horn sounds so weak or is mine busted? If that is normal is there a plug and play oem replacement from another vehicle that sounds better?
Thanks
Old Oct 10, 2014 | 09:12 AM
Jomoka's Avatar
They are puny sounding, even when stock.
I got some horns from a late 70's full sized Cadillac in a PnP. I only used two, but they come in sets of 4 (all different tones).
Makes it sound a bit more assertive, not like a palm buzzer.
Old Oct 10, 2014 | 02:37 PM
wyoming9's Avatar
Red face
I used after Market horns Not bad
Old Oct 10, 2014 | 04:30 PM
tantacoma's Avatar
On my 1st gen 4runner, I swapped in a single horn from a Jetta.
On my Tacoma, I'm using a pair of horns from a Lexus LS400.
Old Oct 11, 2014 | 10:01 PM
TheDurk's Avatar
I swapped in some high power FIAMM horns back in 1999, the first year I owned it. The stockers were pitiful.
Old Oct 12, 2014 | 11:07 AM
sharrack's Avatar
That was a day 1 mod when i bought my 99 runner.
Bought a few blaster horns and now its an attention getter !
Old Oct 13, 2014 | 02:22 PM
IDM's Avatar
IDM
Are any of the horns you guys mention plug and play? with the same connectors maybe from a lexus or other Toyota?
If not is it just splicing a couple of wires together? I don't want to get into a scenario where I short out the fuse when I use the horn, fry stock wiring with aftermarket horns or can't fit the new horns in the same exact spot.
I appreciate your suggestions
Old Oct 14, 2014 | 05:14 AM
Jomoka's Avatar
I'm sure the Lexus horns are PnP. The Caddy horns were - other than a slight bit of grinding on the bracket here and there, then the wire plugged right on.
Old Oct 15, 2014 | 11:12 AM
IDM's Avatar
IDM
Can anyone verify a horn that is plug and play and fits in the stock location?
Thanks!
Old Oct 23, 2014 | 10:07 AM
IDM's Avatar
IDM
I actually found the horn housings to be both broken and completely missing.
I think this was causing the wimpy horn sound on my car and probably everyone elses. I don't think they put a bad horn in the car to begin with.
Old Oct 23, 2014 | 11:00 AM
TheDurk's Avatar
Nope. It was wimpy new. I noticed it on the drive home from the dealer in 1999 and I swapped the horn that year.
Old Oct 24, 2014 | 07:17 AM
Jomoka's Avatar
Maybe his were even wimpier than normal?
urabus
Nov 10, 2015 07:38 PM
toyotasaurus
Sep 24, 2015 03:30 PM
4Xtruck
16
Sep 24, 2015 09:38 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
xzen73x
Sep 14, 2015 03:00 AM
