- Check Engine Light solution
- Sirius Sportster 5
- coolant flow issue after head gasket replacement
- project overhaul - 02 4runner
- 1996 Tacoma problem with clutch
- anyone using adjustable bilstein fronts?
- Swapping coilovers, Tacoma to 4Runner... question
- Question about PO420 code
- How to tell if 4WD is working?
- Will it work??
- Bad vibration
- drive train mod plan/price advice/opinions please
- Key Fob Remote Entry Price/Source?-2000 4Runner
- Regearing 02 4Runner Sport ?'s
- Blackberry and the factory alarm
- Toyota Fender Flares
- Anyone know of a shop in Atlanta, GA that would install Cornfed lift kit?
- Hella 400s on ARB?
- 99 4runner with 5speed/e-locker sport up on C-list in Boulder, CO
- Radiator brand
- alignment specs, whatcha think??
- Direct fit(or almost) muffler swaps.
- Looking at this Tacoma
- TRD Decals My Version
- Heat\AC Blower motor and fan
- trans precaution maint.
- Child's car seat for a 2001 dbl cab Tacoma
- Leaky Head
- Do Hella 500's on the front bumper affect engine temps + mileage?
- Rear Wheel brakes locking up in cold and wet weather.
- Rear diff stud spins. Fix it help?
- Looking for someones old lower skid
- help harmonic balencer came loose
- pre-runner front bumpers?
- Sunroof problems
- Cherokee ARB bumper 4runner??
- Heater problem
- Can I plug FPR hose?? (ISR mod)
- LED 3rd Brake Lights now available for 3rd Gen's!
- What condition is my t-belt in?
- My 4runner sucks in the snow....
- rear sway w/ lc coils??
- Grill Removal
- Weird brake problem
- Costco Tire price ...is it good?
- Speedy is a GOD!!
- Power locks/keyless entry & remote start problem
- 01 4x4 tacoma suspension/steering parts MAKE AN OFFER
- Annoying Squeek
- 2000 4runner 4WD not engaging
- How to correct off center steering wheel?
- trutrac vs lockrite in 4runner with ABS
- Can you run 2 different gear ratios with ADD??
- Need help and advice-ujoints/driveshaft
- wiper fluid light wont go off...
- 4Runner years with factory 4.56's???
- power steering berings replace?
- Weird Problem w/ 4Runner
- 02 tacoma oem E-locker swap
- offset axles?
- cold start idle speed
- which winch for my tjm?
- harsh ride - ideas needed
- Front Oil Seals ??
- Anyone have any rear springs?
- I need some help....please.
- suspention lift confusion. Will this work?
- 3 Questions About My 4runner!!
- Hood Flex
- 98 4runner rear springs help ?????
- a/c buttons and knobs not working
- Supercharge or Not Supercharge
- FJ wheels on 04 Tundra
- Box Size
- Master Cylinder a normal problem? 1998 4runner
- 2 unrelated Questions. Belt replacement and Intake?
- what brand of clutch are you guys running?
- Strawberry Milkshake...Atf in coolant overflowing CRAP!!
- Will a Jardine Tacoma Catback Exhaust work on my 98 4Runner 4x4?
- Who makes the best 5VZ-FE headers?
- O2 Sensor and PO302 Misfire help
- Transfer Case slipping out of 4HI...
- 00-02 taillights in 98 4Runner??
- Performance Module
- Brake Bleeding
- Coil install
- rounded out axle shaft splines - anything else?
- Part # needed for 1st gen TRD Supercharger idler pulley
- What is this black rubber piece?
- Crawler gears in a 3rd gen?
- '97 4Runner: Potential HG Issue??
- Boosted guys...what is Wideband?
- TRAC OFF help
- po302 code 99 4runner 3.4
- problems doing my LED switch
- front end realignment after 3in susp. lift on 2003 toyota tacoma
- ARGHHHHH Can't figure it out...!
- Torque for Transmission Mount (Rear Mount) Bolts
- How do you disconnect the parking brake cable from the handle?
- Fuel Filter Nuts Corroded
- !!!! i have a slight emergency with fuzes and battery!!
- Sloppy Idle/ Motor dies
- Tech Question: Front Wheel Bearings Greasing
- Blah ,I keep second guessing myself!!!! - front lift
- SOS fuel filter
- wheel and tire question
- 300k Miles+ - Proper Maintenance for Older Toyotas
- Major Automatic Transmission problem
- Engine stalls when put in gear
- Rear wiper
- parking brake light with a twist
- 2000 toyota 4runner trany problems or not?
- Can anyone tell me what this is?
- Self adjusting rear brakes a myth? (pic)
- Windshield Wiper system problems HELP
- Tacoma to 4Runner diff swap... Will it work???
- does any one know?
- Are front rotors separate from wheel hub 98 4Runner?
- auto tranny question
- Quick headlight question for a 1998 4runner
- Got some wheels today
- Need opinon on parts prices
- Nedd qpinon on parts prices
- arb winch bumper,winch and adjustable coil overs
- 98 runner cd player
- 99 lift question
- Need help diagnosing a problem!!
- FJ 80 coils
- Brake issue... Does this sound "normal"??
- 95-97 tjm t17 on a 2000 need pics info please
- Double Cab 411
- 99 manual shifter knob to 05 auto shifter knob mod
- 315/75/16 Maxxis Bighorns on my 98 4Runner
- 01 & 02 tail-lights, will they fit a 2000 4runner?
- LCE Short Shifter
- Complete Bushing Kit
- Suggestion for rear bumper that won't interfere with Uhaul hitch
- Odd auto window malfunction
- Interior Hi-Lift mounts, post up pics!
- 5.29 for sale?
- New 3rd Gen (again)
- Breather end cap
- intermittant no start, idiot lights, not even a click
- Tranny Temperature Concerns
- Road Trip - South Central Tunisia
- Strut Bushings Gone!
- 99 4Runner Wont Move Forward in Drive
- GOT A STUPID IDEA (for us w/o the e-locker///wipes tear away///)
- O2 sensor p0133 bank 1 sensor 1 NEW TO FORUMS
- Poly Body Mount Bushings - Worth Every Penny
- Verdict On The Airlift Air Bags (air Lift 1000)
- Coils for my 02 4runner
- Rear Drum Locked... How to reverse shoe adjuster?
- Is this normal for a Tokico shock bushing? (pic)
- CV Boots
- Oh upper rear shock mount let me count the ways I Hate you!
- Rear E-locker and 4.30 gears
- Finally new shoes
- Looking to buy a newer Taco soon
- Transmission slipping?
- Traction control problems in cold weather
- Can Paintless Dent Removal take these out?
- starting problems
- Who was member here that could get dealer parts?
- Front end help
- Sulfur Smell?
- Did Toyota sell a stick shift mated to a supercharged motor?
- Going to small tires
- 4 runner pad upgrade
- How long do OME shocks last?
- I want to hollow one or both cats on my 99 4runner.
- rear axle seal leak again
- Truck almost dies when decelerating, help please.
- Post Manual hub install observations 4Runner
- Someone please.... put it out of its misery...
- Would You
- 1996 Tacoma, LSD?
- Question about 4runner transmission
- Power Antenna parts question
- Where + how to carry a long gun in your 4Runner?
- Guess What I Bought!
- OEM Sway Links VS. MOOG (aftermarket part)
- AC Help Requested 4runner 2002
- Oil pick up tube to oil pump sealing
- Time to say goodbye
- Are all shocks universal? Also wheretbuy oem/good parts
- Looking at a 99 4Runner. Questions
- 2000 4runner Sr5 Rear Suspension Work And Spring Saggy Sag Awful!!!
- Was board today...so
- Transmission q
- I spent $3600 in aftermarket parts this past week for my stock 4runner
- Oxygen sensor bolt stud size?
- 99 stock ride height??
- 1996 4runner
- E-Locker Retrofit TOTAL cost & wiring?
- Cold idle
- Noisy A/C blower motor
- SS 1.2 or SS 7.2?
- 5 speed and leather!
- replacing stock springs with stock springs
- Which wiring harness to buy?
- Slotted vs. Drilled Rotors...
- 1999 4runner
- 2000 4runner Compass, and temp
- Crankshaft Pulley Wobble
- 96 4runner braking vibration
- Frame failure? How Screwed am I?
- '01 Power Window Problem: Relay, Fuse?
- *** S!CK A$$ SAFARI RACK BUILD *** Part Deux. 95% Complete
- Decisions, 2 1/4 or 2 1/2, inch exhaust 99 4runner?
- 2002 VSC Problems
- problems with my new runner ARGHHH!!
- A few general questions, and winterization help.
- what to do now?
- so i removed my cat and installed a straight pipe
- Hey guys check out my New (used) 4runner!!
- Price check
- Pics of my 1995 Tacoma w/ new lift
- Best Place For Firewall Wiring Passthrough ??
- A/F heater circuit dead?
- What should i monitor?
- Stalling with no air filter tube
- Don't forget to plug those inlets in the radiator!
- Hooking up an oil pressure guage
- Left Center Pillar
- 2001 4runner- which rear springs
- New vibration.
- BudBuilt Installation Questions HELP ASAP!
- Parting ways with My 4Runner...Sell or Trade? (Poll)
- maintained OD switch on 3rd Gen 4Runner
- New Member Looking at a '99 4Runner Limited w/ ELocker! (pics attached)
- idle problems
- Crap! 4500 in repairs?!?!?
- 01 Tacoma coilovers direct fit for 02 4Runner??
- Which on these 2 Runners would you get?
- 2WD to 4WD.. Question
- 3rd gen interior acoustics
- *** S!CK A$$ SAFARI RACK BUILD. *** Part One. 50% completed
- Spark Plugs
- I swear ive searched. I need a write up for toytec lift please.
- 03 tacoma gas milage
- who among us has the highest mileage on our RUNNER??
- major problem with rear diff
- '02 Taco, Time to Replace Shocks, Lift It??
- I need your advice on 4runners!
- Toyota 4Runner vs. Jeep Wrangler Unlimited
- New runner
- Tacoma w/ 5" of lift..what to do with tires now?
- Lets see what 4runners yall GOT!!!
- A340F transmission issues; bogs at 45mph
