SOS fuel filter
Old Nov 28, 2008 | 03:02 PM
hopper's Avatar
SOS fuel filter
1998 4runner.
Changed out fuel filter went easy... to easy. Now its leaking from both ends and i have taken it off and put it back with no solution.
How do I fix it???
Old Nov 28, 2008 | 03:03 PM
olharleyman's Avatar
Replace the plastic clips on the lines
Old Nov 28, 2008 | 03:05 PM
hopper's Avatar
what plastic clips?
Godzilla's Avatar
Few things;
easiest..is it on the right direction?
also..how are the threads on the fuel line? Try cleaning up the threads where past where they were originally in the old filter. When I changed out my filter, this was the case.
And how are the threads on the inside of the filter? did you cross thread?
Old Nov 28, 2008 | 03:06 PM
corax's Avatar
make sure that you have 1 copper gasket on each side of the banjo fitting (bit the bolt goes through) on both ends of the filter -- beyond that, any minor leaks should go away by just snugging up the bolts a bit more (don't go all "crack-head tight" on them though)
Old Nov 28, 2008 | 03:09 PM
hopper's Avatar
Originally Posted by Godzilla
Few things;
In is closest to the fuel tank correct?
This is for a 3.4L there are no banjo fittings, its under the driver seat.
Old Nov 28, 2008 | 03:11 PM
hopper's Avatar
Do I need to wrap the ends with teflon tape?
Old Nov 28, 2008 | 03:16 PM
Godzilla's Avatar
no dont use teflon tape. it should not be needed.
did you bolt the filter on before connecting the lines?
also, try it again and put a little pressure on the tightening.
It took me twice to get it snug.
Old Nov 28, 2008 | 03:21 PM
Godzilla's Avatar
This may help;
http://www.4runners.org/writeups/fuelfilter/index.html
sometimes the lines are a pain to be perfectly straight
Old Nov 28, 2008 | 03:31 PM
hopper's Avatar
Ok got it to work! THANKS again YotaTechers for the help.
For future referance...
Put the lines in and tighten them by hand first then bolt it to the vehicle.
Old Nov 28, 2008 | 03:40 PM
Godzilla's Avatar
Nice work. Yup those lines are picky, but when it is carrying pressurized fuel, i guess they have to be perfect for a reason
Old Nov 28, 2008 | 04:16 PM
scuba's Avatar
Wouldnt it be meth head tight ??
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
pyramid
Jul 30, 2015 10:05 AM
ddg71
Jul 24, 2015 01:24 PM
Fundy Rider
Jul 16, 2015 01:35 AM
