Spark Plugs
Old Nov 13, 2008 | 08:34 PM
wormhole's Avatar
Spark Plugs
I feel really stupid for asking this but if you buy spark plugs though the toyota dealer do they come pre gapped or does the gap need to be adjusted?
Old Nov 13, 2008 | 10:50 PM
SoCalPaul's Avatar
Most plugs come pre-gapped, but I always check them.
Old Nov 14, 2008 | 12:59 AM
Elton's Avatar
how do you check the gap on the dual ground plugs ?
Old Nov 14, 2008 | 07:57 AM
trbizwiz's Avatar
get the denso iridiums. They dont need gapping.http://www.densoiridium.com/installationguide.php
Old Nov 14, 2008 | 10:01 AM
mikgrail3's Avatar
They are pre-gapped. That's why they come with the cardboard over the ends, so the gap doesn't get tweaked. I double check them anyway, as well.
Old Nov 14, 2008 | 10:24 AM
rdlsz24's Avatar
Only takes a second to double check the gaps before installing.
Rob
Old Nov 14, 2008 | 11:42 AM
jason191918's Avatar
For what it's worth just gap 'em.
Old Nov 27, 2008 | 08:44 AM
wormhole's Avatar
I should've checked it sooner but the dork at the counter gave me the spark plugs for the 4 cylinder 4runner and not the v6.
Sparkplug replacement will wait for another time.
Old Nov 27, 2008 | 03:43 PM
bankerkys's Avatar
As stated above, get the Denso Iridiums. Fantastic plug and no gapping required.
Old Nov 28, 2008 | 03:07 AM
ARB1977's Avatar
I also got Denso Iridiums the gap was out of spec...even with Iridiums i would still check. 50K on them so far.
Old Nov 29, 2008 | 09:02 PM
wormhole's Avatar
Was looking at replacing the plugs today but I'm a little confused on what hoses need to be moved to access the wire/plug on the drivers side near the firewall.
Old Dec 1, 2008 | 08:06 AM
cackalak han's Avatar
Iridiums don't do jack. And if they're any more expensive than the stock plugs, you're just wasting $$$$. Stick with stock plugs. That's all you will need. And please don't give me crap about how they increase HP, burn better, last longer or other BS.
Wormhole, driver's side is a bit more tricky, since the space is tighter. But at the same time, it is really easy to do, unless you have giant banana hands. I usually take that bracket that is bolted on right by the spark plug holes (IIRC). Other than that, just start uncliping hoses as needed. Not too hard at all. If you are up in Utah, you can bring it by my house.
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
accuracy
Aug 4, 2015 08:05 PM
defrag4
Jul 31, 2015 10:50 AM
