Hooking up an oil pressure guage
Old Nov 15, 2008 | 03:43 AM
dbcx's Avatar
I tried searching and couldnt come up with anything. I was thinking about putting an oil pressure guage in and maybe a volt guage while im at it. Having not looked at it at all im assuming an electrical guage.
Can i come of the wires going to the dummy light? Or will the guage take a different sensor? This is for my 97 4runner
Thanks
Old Nov 15, 2008 | 04:26 AM
ozziesironmanoffroad's Avatar
im PRETTY sure for an oil gauge ur gonna need a oil pressure sender. i think you just have an oil pressure switch, that when the oil pressure drops, it turns the light on.
Old Nov 15, 2008 | 04:59 AM
dbcx's Avatar
Yeah, i wonder if they make a dual one so i can keep the light also. I thinking of getting one of thos guage pods up the pillar. Not sure if i want two or three i hate to duplicate the temp guage. I dont like that.
I had thought about putting them down under the radio, not sure id like that plus i would have to make something to put them in so they looked factory.
I found a pod that goes completly top to bottom just like the factory one is in there now. 3 pods black , 2 pods same color as interior
Old Nov 15, 2008 | 05:15 AM
jason191918's Avatar
https://www.yotatech.com/forums/f116...ensors-153167/
https://www.yotatech.com/forums/f116...-gauge-150855/
https://www.yotatech.com/forums/f116...-gauge-142656/
https://www.yotatech.com/forums/f116...-gauge-137722/
https://www.yotatech.com/forums/f116...e-gage-127336/
Old Nov 15, 2008 | 11:14 AM
pattycakes77's Avatar
when i did my gauges i bought an autometer oil pressure gauge that came with a sensor. popped one of two spare plugs out of the engine and screwed the sender in. ran the sender wire through the firewall, tapped a switched 12 volt power source made another ground, ran all wires to the gauge, and tapped + and - from a interior lighting source for the gauge light, mounted gauge and i was done. it was really easy and not messy like a mechanical gauge, electric is the way to go!
Old Nov 15, 2008 | 12:01 PM
OSU4Runner's Avatar
Here is the write up I used. Have fun removing the oil plug....spray it with lots of PB blaster and have some patience.
http://4runners.org/writeups/gaugeoil/index.html
Old Nov 15, 2008 | 12:03 PM
OSU4Runner's Avatar
I think the biggest gauge pillar you can get is a dual pod. Thats all I could find and I searched for hours. I've heard of people modifying tri-pod from other vehicles though. Let me know if you find a tri pod for the 3rd gen!
Old Nov 15, 2008 | 12:27 PM
dbcx's Avatar
I did find a 3pod here they 2 and three. Try this:
http://www.gaugepods.com/toyota_t.html
Im thinking about oil,trans temp and voltage.
Old Nov 15, 2008 | 05:05 PM
OSU4Runner's Avatar
Those 3 pods are for 84-89 and 90-95
Old Nov 15, 2008 | 05:28 PM
dbcx's Avatar
Aww . Good catch I looked right over it. I guess i would of noticed when i ordered one and couldnt find it . Guess ill keep lookin
Old Nov 15, 2008 | 08:22 PM
that's what i did on mine, i might do others later but those were the big 3 that i wanted first. and yes, do share if you find a 3 pod pillar for the 3rd gen.
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
