- fresh air problem? 4th gen
- 285's and 1" performance products springs
- Emergency Bracke Comes on, Then Goes off. Ideas??
- My new 1987 Toyota pickup
- HILUX badges from Australia
- 54mm socket needed!
- blower motor
- quick question re: turbocharging the 22re
- A/T light on again
- Code 21
- 92 Wont start
- 22re startup idle is low
- Parking in the garage is overrated anyways!
- Reverse + E-brake = rear adjustment?
- Cooling system flush
- Winter and manual hubs - locked or unlocked?
- Adjustments in what order for idle speed?
- I give up! Please suggest/design my lift!
- My latest Modification
- really high rpms @ startup
- 2005 Tacoma MPGs
- Another 3.0 Funky Idle Question
- 31 x 10.50s On a Taco (allready searched)
- 2nd gen to 3rd gen bumper swap?
- High Idle??
- '99-'02 JDM style clear corners
- Can you help me buy Mickey Thompson Wheels for my 4Runner?
- 3 mocha lattes a day!
- 05 tacomas
- Help! 3rd gen problem
- Let it snow Let it snow Let it snow
- Help! I need a reality check...
- Problem getting into first gear
- Knock sensor wire mod
- End of the year bonus cash!!
- LED Turn Signal Question
- Rear Sway Bar - Need it or No?
- 85 engine problems ...
- Anyone have a shop in NJ? Or any shadetree mechanics in the area?
- 02 Window switch
- Fuel pump housing
- Will a 84 4wd truck wheels fit on a 83 2wd
- Tacoma skid plates cheap
- MAF sensor on 22RE
- Wiring Gurus! Gather!
- Have any 4th gen owners tried this...
- one knock at engine start
- Trust Worthy Auto Transport Company?
- 4Runner in Germany.....
- Receiver and Hitch
- Exhaust question...
- OME Coil Bind
- Locked rear ends and towing trailers
- Would this tire fit?
- missing problem solved
- tire problems?
- URD kit installed, where to start with tuing the FTC1????
- Adding red factory door lamps
- auto power window switch mod for 97 runner
- Quick Bolt Pattern question
- cheap wheel spacers
- 88 toy
- Dream expedition
- Won't let me shift into gear - or stays in park
- Cold air induction!!
- Help needed: rear lower control arm reattachment
- Turbo 3VZE?
- need help now!!!
- What do ya think?
- Buddy rear ended me today
- CLUNKING NOISE???? transfer case?
- ski carrier on No-rack 4runner
- Removing Freeze Out Plugs
- Where to find cheap 4.5 inch lights
- Wouldnt start???
- 1999 4Runner Sport
- Strange wire???
- Any opinions on the 04 or 05 4Runner SR5 Sport
- Gen II Dash Pot questions?
- 5spd 3.4 owners
- o noez!!! my brakes suck!
- Blown Head Gasket on 2nd Gen.
- Engine Question
- Best place to get OEM oil filter for 4runner?
- Shopping List
- rear bumper?
- Installing Rebuilt Head in Morning
- Badland Bumpers
- New Brembo rotors & PF Pads...WOW!!
- Sring helpers?
- Injectors
- Budget bed liners
- If you were to paint your rig...
- Tailgate hinge bolts
- Will T-100 rims fit on an 87 Runner?
- 04 oil change
- Fed Up
- 3.4L Supercharger Bracket...???
- 3rd Gen Air Filter Dims
- New Shoes
- 3.4L Performance cams.
- When does a 22r carb engine red-line?
- Body lift and rear bumper
- Squeaky Clutch on 97 V6 (Have already searched)
- 1987 Toyota 4x4 Pickup Truck,More Questions
- Question about Tacomas
- Need towing help -
- 3rd gen rear axle seal leak solution?
- Leaking oil
- Someone slashed my tire last night, can I drive on the smaller spare?
- HVAC blower not working???
- Where to buy 5VZ-FE header flanges
- Low Profile Roof rack mounts
- What are my options on front bumpers?
- AR-767 Rims
- Are 3VZ and 5VZ MT bellhousings the same?
- Anybody wanna play! ! ! ! ? ? ? ?
- Question on changing tire size on my 04 4runner?
- TJM & Powder coating
- opinion needed 2004 tacoma..new tire size...possible lift?
- Bilstien Choice???
- '99 3.4L cold-only hesitation
- 22RE Exhaust Question??????????
- need advice
- ARB PRADO on a Tacoma?
- My bad idle and 3 cylinders
- Tach jumping
- Another gear question/guess
- AHHHH!!!!!! I wanna slow down!!!!
- Help Engine
- Is this the ARB I need?
- 3vze Valve Adjustment
- Help w/ Highlander H/L Bulb
- Anyone have Hella 500s with a Brush gaurd?
- Whats your cruisin speed?
- Saw A Tacoma
- U joint replacement
- "Mule MFG" TJM / ARB style bumpers $600 shipped??!
- Sorry Camry Snow Tire Question
- For the Taco dudes......
- SEMA Coverage
- TJM front bumper replacement t-15???
- What if I find and eLocker?!
- 2" BL: TJM to Body space filler solution
- Bilstein vs TRD Bilstein
- Modification questions...
- My custom 2 piece ported 3.0 intake..heh
- 4th Gen Alignment Specs-help
- Just got an Optima Blue top mounted
- Super charger San Diego
- Annoying Ticking Device..aka VSV
- New gears and gas milage question
- Bull Bar
- Flamethrower
- Ticking and hard idle
- Hot drums!!
- Foglamps for 2000 4R
- Leaking automatic?
- Wheel and Tire question...
- 2005 lifted Tacoma
- Clock
- steering replacement
- Brush Guards
- Time Bomb?
- Event Data Recovery module?
- Toyota Japan
- My curiousity got the best of me......
- E-brake????
- Newbie has a few transmission questions ???
- Fixed problem and want to know long term damage
- tacoma seatbelt needed. Anyone?
- anyone having this problem
- OME 882 or else...
- Transmission noise
- Why? here is a Long Bed X cab dually Yota WHY!
- Mysterious buttons
- How to park in a compact space
- New here: Question about 2002 4Runner
- side vent problems
- NO heat, getting cold...
- 2.7 Prerunner exhaust help!!
- redline oil in tranny
- Rust :(
- Slider issues.
- 22re running rich
- Stock 4runner and Uwharrie
- 33/1050r-15's
- Good shop in Northern Wash
- My battery got hooked up backwards!?! Help!
- Shocks for Taco? Rancho?
- Headlight wire harness
- Toyotas - choice of US Special Forces
- How NOT to test your RTI Score!!
- Height of Stock Tacoma 4wd coils?
- Supercharger Removal? - Going back to Stock
- Pics of my pimped out Surf
- Our 2005 4Runner came in a couple of days ago (plenty of pics)
- gears, where to buy
- Look what the UPS guy brought me today...
- I cannot program my new alarm remote! help
- 02 4runner wheel upgrade
- Show Pics of Your Yota at Work!
- 2nd Gen Tail lights For Sale
- 98-02 Headlamp conversion
- Decision on next truck
- Need help I.D.'ing Speed Sensor Wire on '91 4 Runner
- Revtek combined with OME 881s and Bilsteins
- Manual hub issues
- 05 Tacoma commercial is AWESOME!!
- Air Filter options on a 3.0
- Cold Air Intake (MAFci System) development, anyone interested(V8 and V6?
- hellpp please
- 2 questions taco guys.....
- 3.4L cracked head war
- 3rd GEN Fiberglass Fenders
- Anyone Have a Scanned Factory Repair Manuals?
- Bent Stuff
- 3.0 not starting.... no fuel!
- Intake question...
- Loss of power then engine cut-off...
- safari rack i'm designing, pic may be crap
- master cylinder
- Q: Taco 4X4 / PreRunner Rear Leaf Height
- "High Flow" Cat?
- Ordering a Rear Limited Fender
- 22RET internals vs. 22RE internals
- Maint on aisin hubs 99 Taco?????
- 2nd Gen 4Runner NHTSA Rating
- Thy Truck, Part 1
- Rear Window Defrost repair tips?
- Bad gas & O2 sensor
- Running Fog Lights Independant of Headlights
- 1st Gen Rear Window Will not roll up
- Want a 1st Gen - Have a few questions
- tacoma antenna
- RS9000x w/ In Vehicle Adjustment
- How Much Protection is Needed?
- ToyoDa?
- Ball Joints, Life and Replacement
- Tacoma Hunkering Down for Winter - Bed Weight
- Looking for a short or long block
- Can thule equipment be attached to factory roof rack?
- 1st gear on manual trannys - a bad thing?
- question on 4Runner Aluminum Skid Plate
- towing, weight, gears...
- ? about 4Runner History
- gears from 4cyl fit a v6?
- 4RUNNER electrical problem
- Help me pick my suspension!
- Can someone please exlpain "gears" to me?
