54mm socket needed!
Hi guys, I took off tomorrow hoping that the local Auto Zone would have a 54mm socket for rent or for sale so I can finally get my Brembo/Performance Friction/inner outer wheel bearing job going but I guess I was wrong! Does any one know where I should look locally for a socket this large? Does any one have one I can borrow Ill pay 2 way shipping"? I would hate to buy one, I know I wont need it again for years but if I have to I guess I will! Does any one know of any other way to get the hubs off? I mean any other tools that I may have handy; I need to find out before I start pulling things apart! Thanks again, Matt. Oh what size in inches would this equate to, I cant think right now
I think the manuals cause less wear on the cv's......much less wear on a lifted IFS for sure. http://www.4x4wire.com/toyota/maintenance/front_end/
check this one out....all the info I needed. It was a really good write up...hope it helps
There is also the slight gain in power. I notice it when I have the hubs locked on my '85, there is a noticable power drop due to the frictional losses of the front end components turning.
Knuckle Service Tools
We get lots of calls asking where to get the special tools needed to service Toyota knuckles. With some searching we found these high quality service tools. The scale allows you to measure the knuckle shim preload. To use: remove tie rod, attach the scale to the steering arm. Then adjust the shims until it takes 12-15lbs of force to rotate knuckle.
Snap-On 54mm Hub Socket $24.99
Knuckle Pull Scale $9.99
Found these at Marlin Crawler Website
Originally Posted by waskillywabbit
SEARS Craftsman 2 1/8" socket w/ 3/4" to 1/2" adapter so it will fit on a 1/2" drive ratchet $30
If you got manual hubs and need it now, just BUY one, you'll need it again.
54 mm = 2.125984252" = 2 1/8"
The FJ-62 and your 85 have baiscally the same axle except the 62's is longer and the diff is 9".
Originally Posted by sschaefer3
Is that the socket that goes on the bug huge nut on the Toyota streight axle? If so I need to get one too.
You need to get a spring scale too...
A cheaper alternative. $12.94 shipped
Originally Posted by Flamedx4
Use a screwdriver and a hammer and some common sense. It ain't rocket science.
"Common sense sure ain't too common."
[[ a hammer and a screwdriver works real well on a torque wrench]]
EggZactly! Torque wrench, breaker bar, monkey wrench, all the same... LOL. You guys just can't take a joke...
Road Bull
Oct 10, 2015 04:55 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
FS[NorAtl]: 1989 pickup beds and leer cap Rhode island
mickyd9990
Jul 6, 2015 09:01 AM
