Transmission noise
Old Nov 3, 2004 | 06:19 AM
RTdawgs's Avatar
Transmission noise
I get a noise when i shift the tranny lever to L. D to 2 is fine, but 2 to L makes a noise. It can only be heard if the window is down, radio off, and its quiet. The noise is difficult to describe, its sort of like a "squeezing" sounds or "burbing sound", the sound you get when grease is squeezed through a small opening.
Havent had the opportunity to crawl under and listen/watch while someone else shifts the lever.
This ring a bell for anyone?
Old Nov 3, 2004 | 08:08 AM
dragr1's Avatar
Why don't you go to Tellico this weekend and we can have plenty of people look at it.
Old Nov 4, 2004 | 05:59 AM
RTdawgs's Avatar
Bump
Old Nov 4, 2004 | 07:10 AM
ilocan's Avatar
Ok, I just went out and tried putting mine in L and sure enough it makes the same noise you described. Only mod to my tranny is the cooler, so I guess it's normal unless someone else says otherwise.
jashoeuh
Nov 18, 2024 08:08 AM
crammit442
7
Nov 29, 2017 12:30 PM
mskalmus
May 28, 2017 07:51 AM
mengquis
Jul 13, 2015 10:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
