OME Coil Bind
Old Nov 7, 2004 | 01:43 PM
User 051420's Avatar
OME Coil Bind
I was checking out my truck today, and I realized that 4 of the winds on my OME 891's were touching up at the top. Sag city, I'm guessing. I'm just curiuos if any of you have noticed this and how many winds are touching. Also, my panhard is almost level again. Sagging is happening.
Old Nov 7, 2004 | 04:22 PM
914runner's Avatar
SBS!!!!!! (Saggy Butt Syndrome)
Old Nov 7, 2004 | 05:08 PM
sschaefer3's Avatar
Well have you heard about the Sonoran Steel Trac/Panhard bar and the Super Soft bump stops?
Call ARB and ask them why your saggin, they are my BEST sales people.
Old Nov 7, 2004 | 05:25 PM
Yah yah...I know..I need the longer bumpstops. :pat:
I was just curious how common this is and to what extent.
Old Nov 7, 2004 | 05:28 PM
sschaefer3's Avatar
If you have 891's and stock bump stops, you have it.
You can always buy another set of 891 coils in a year or so.
Old Nov 7, 2004 | 05:49 PM
I smell a sweet price for the bolt on bumpstops and drop bar via a group buy.....:winkwink:
I'm probably correct when I assume that ARB won't warrant the springs.
Old Nov 7, 2004 | 05:58 PM
sschaefer3's Avatar
I think they will ask you if you have lowered bump stops. Now all 891's do settle with time, so you have to destinguish between that and over compression.
But the bottomline is that if you don't drop the stops, you'll over compress.
"The 890s and 891s were never designed for the 4Runner due to the amount of lift you get. Once you go above the 2" range you should be lowering the bumpstops to keep from over compressing them. When the coils start dropping down to where they are touching each other, that is what causes them to go flat from coil bind." ARB Engineer from ARB in Seattle in an e-mail to Jayson Blanchard
Old Nov 7, 2004 | 06:02 PM
Why not make the winds further apart?? I've screwed myself on this. When I first did the lift, I had no clue about the bumpstops so I just cut off the cones.
Old Nov 7, 2004 | 06:07 PM
sschaefer3's Avatar
The coils are progressive, they are desined that way. Sorry, I just make the fix, not the product.
ZGjethro
Jun 7, 2017 11:04 PM
A2theK
Oct 14, 2015 07:10 AM
Obmi
Oct 4, 2015 11:30 AM
the_supernerd
Oct 1, 2015 09:20 PM
89YodaRunner
Sep 30, 2015 02:18 PM
