Help needed: rear lower control arm reattachment
Old Nov 7, 2004 | 07:18 AM
amorphous's Avatar
Installing my rear 2" cornfeds (solo) and I thought, hmm...I'll get more space to work with if I unattach my lower contol arm....driver side, by the gas tank....so....anyway....need suggestions now on how to re-attach! Got the bolt on and 1/2 thru.
thanks,
aaron
Old Nov 7, 2004 | 09:22 AM
BruceTS's Avatar
use a ratchet type strap or some rope . loop it around the axle housing and a point in front of the front mount. If your using the ratchet just tighten it up till the bolt hole lines up. With rope looped around and tied together put a screwdriver between the 2 lines and twist them together til the bolt hole lines up.
Old Nov 7, 2004 | 02:05 PM
amorphous's Avatar
THANKS BRUCE! - GOT IT!
regards,
Aaron
lledwod
Aug 30, 2016 01:03 PM
coryc85
Sep 9, 2015 06:24 AM
icentropy
Jul 14, 2015 10:23 AM
shisha1999
Jul 13, 2015 11:09 PM
icentropy
Jul 11, 2015 07:21 AM
