Turbo 3VZE?
Old Nov 6, 2004 | 10:33 PM
Keggo's Avatar
Turbo 3VZE?
Hey guys, I was just wondering if it was possible to turbocharge a 3VZE. And if so, do you know anyone that has done it? I'm looking to get a little more power... but am doubting get a turbo since I want to get a safari snorkel. Which brings me to my next question... would it decrease my power if I had the snorkel, since it's such a long tube?? Thanks in advance!
Old Nov 7, 2004 | 12:03 AM
Praufet's Avatar
some guy did it, he posted on here and on pirate can't remember his name, he just welded a turbo flange the the y-pipe, and fabber the other needed parts. Not really for me cause gas is so expensive, but if that's your bag, go for it.
Old Nov 7, 2004 | 09:50 AM
AverysDad's Avatar
yea just go over to pirate4x4 and do a search................mostly fabbed everything himself
Old Nov 7, 2004 | 10:48 AM
Waterboy's Avatar
Search for 3.0 turbo
https://www.yotatech.com/forums/show...ight=3.0+turbo
Old Nov 7, 2004 | 11:00 AM
Keggo's Avatar
cool... Thanks... i probably won't put one in, unless gas drops to like 50 cents a gallon... yeah right.. anyway. thanks again!
Old Nov 7, 2004 | 11:21 AM
914runner's Avatar
Swap in a 5VZ-FE! Loads of more power and 20mpg!
Old Nov 7, 2004 | 11:24 AM
Flamedx4's Avatar
Not to mention the absolute certainty you'd blow it up unless you really knew what you were doing. The head gasket issues, making the engine breath better, and the fuel system management issues are not realy shadetree mechanic items. Turboing is not as simple as bolting one on.
Snorkel? Look at Cold Air Induction kits. Notice the short, smooth pipes that replace the convoluted long factory pipes? Notice how a bigger air filter is located outdoors where more air can get to it? Look at things like the deckplate mod - it lets in more air. Simple concept really, get the air in more efficiently. Now, look at a snorkel.... No, it will not give you more power. It will however, restrict the airflow even more.
Old Nov 7, 2004 | 03:13 PM
Keggo's Avatar
so, is the 5vze the 3.4L engine? I was on this one website with a full conversion kit for like 1700 bucks... is it worth it?
Old Nov 7, 2004 | 04:44 PM
kyle_22r's Avatar
considering that you'd probably be putting a lot more into the motor by swapping in a turbo, i'd definitely say it's worth it. you'll get more power and reliability, and most likely better mileage
Old Nov 9, 2004 | 08:56 AM
Keggo's Avatar
yeah... I want a 5vze... what do you think is better... Totally swapping or converting?... I saw this kit online to completely convert your 3vze to a 5vze...
Old Nov 9, 2004 | 06:23 PM
kyle_22r's Avatar
don't think there's anything to really "convert". you could theoretically convert a 3VZE to a 3VZFE which has dual cams and much better performance(and track record) than the 3VZE.
offroad solutions sells everything to do the swap, kind of pricey but a lot of people have gone through them
Old Nov 9, 2004 | 09:37 PM
Keggo's Avatar
that would be cool to make it a dual cam... but... I don't know... my 3vze pulls pretty hard... it only has 44 grand on the rebuild...
TheBFA
Feb 15, 2020 06:55 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
voiddweller
Sep 28, 2015 11:21 PM
Matthew Perez
Sep 28, 2015 05:43 PM
