Time Bomb?
Old Nov 3, 2004 | 10:34 AM
ALEKATNM's Avatar
Time Bomb?
I put a reman 3.0 in my 4runner this summer. It has been ticking since day one. With a stethoscope ive narrowed to the head valve cover area. Do reman engines come with really tight lifters, etc? Does anyone know what it might be? It only does it under load not at idle.
Old Nov 3, 2004 | 10:54 AM
AKennedy87's Avatar
On a 22RE some of the ticking can come from the Valve cover being on too tight. It also can be valve clearance. I had this and gave these a try and it became a lot quieter.
Old Nov 3, 2004 | 02:14 PM
ALEKATNM's Avatar
do you know if the tightness effects the 3.0 valve covers? Because I already have a little oil seepage on one. and I was thinking they might be to loose.
Old Nov 4, 2004 | 03:36 AM
HondaTec521's Avatar
I dont think it's a problem on the 3.0,you should check your valve clearances thou.Pain in the arse.
Old Nov 4, 2004 | 03:41 AM
Cebby's Avatar
The 3.0 has noisy valves and noisy injectors. At least mine does...
Old Nov 4, 2004 | 09:19 AM
Flamedx4's Avatar
Mine does too. Someone on here pointed me toward the grommet for the steering column and when I sealed that I don't hear the clicking any more.
Turning up the stereo helps too!
Old Nov 4, 2004 | 09:47 AM
corvettelvr73's Avatar
The 3.0 is a very loud engine i wouldnt worry about it untill it sounds like all hell has broke loose.
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
smiley52
Jul 11, 2015 05:16 AM
