Injectors
Old Nov 5, 2004 | 05:03 PM
desert whomper's Avatar
Injectors
ok i need new injectors for my 22re, it has intake, ehuast and high flow cat and headers soon. What would be the best injectorswill stock just do or if i get ones with more putput will i get any increase in power?
Old Nov 5, 2004 | 07:02 PM
Gadget's Avatar
Your ECU programmed for the stock size injectors. If you put larger then stock ones in it will run overly rich and that will kill power and can cause serious engine damage.
Unless you have converted the engine over to forced induction, the stock size is all you need.
Gadget
Old Nov 6, 2004 | 03:35 AM
AzStorm's Avatar
The stock size is fine.I would however reccomend getting them balanced or ordering balanced ones.I got mine from LCE.(balanced ='s each injector has the same flow rate +or- a small percentage)
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
themightykhoner
Sep 18, 2015 02:28 AM
larrys93pickup
Sep 17, 2015 07:05 PM
Kytowboater
Sep 17, 2015 11:17 AM
