PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Supercharger with or without the 170 thermo
  2. Cam shaft sensor connector
  3. Missing after warm .Help With codes - 99 4runner 3.4 - codes p1300 p0302 p0300
  4. Rack and pinion bushing
  5. Engine bog down / power loss
  6. Timing Belt Tensioner Compression Solution
  7. Recurring P0420 in open loop
  8. How do I remove or disable the factory starter disable?
  9. Keyless entry not working
  10. 3rd gen runner alternator...did your light come on when it died?
  11. 5vzfe low idle 1997 4Runner auto. Am I just paranoid?
  12. Identify the mystery lines
  13. Help with camber, lifted 6"
  14. Roof rack
  15. Brake pad recomendation
  16. Brake pad recomendations
  17. Questions?
  18. Poor girl has been ignored for a while - 97 4Runner, Clutch, Oil Pan, Valve covers...
  19. 95 taco with power steering question
  20. bleeding master cylinder
  21. trans pan gasket
  22. '97 4Runner auto trans OD down shift issue
  23. Nicks in ABS Ring
  24. Just picked up 97 4Runner and a used lift, few questions
  25. steering wheel off center; centered by rotating tires
  26. 2009 TRD Lift Question
  27. More Custom 4Runner Bumpers
  28. Grinding in drive train at 20mph??
  29. Can you drive an 02 taco 4wd without the front differential installed?
  30. 04 Taco Engine Ping/Spark knock w/ only 79,000
  31. Couple of specific water pump questions...
  32. Lift Question for my 3rd gen
  33. Great place to get supercharger rebuilt in CA
  34. 2002 4Runner with bad mileage
  35. Transfer case overfilled with oil or ATF
  36. Still Overheating (Passed block test)
  37. sticky power steering
  38. 02 taco 4wd double cab front end clunk
  39. Timing belt slippage - how much is too much?
  40. Are there metal stub pipes for the heater hoses on a 3.4 (pic) ?
  41. Mis fire 96 Tacoma 3.4 4x4
  42. Problems with this #1 Cyl Plug?
  43. Coolant Leak - Passenger side behind motor?
  44. Doing the timing belt on my 99 runner
  45. Bent frame reliablity
  46. Limited slip options
  47. 3rd Gen Brake Bell Crank Question
  48. Lookin for a 3rz 4x4 removal thread
  49. Found in my oil pan
  50. '96 3.4L which fan clutch?
  51. Inner hub bearing
  52. Sloppy suspension 99 tall t4r
  53. 2002 4runner doing tbelt but not pulleys need please input
  54. Hot Trans, causing hot engine?
  55. Weight of 3.4L V6 in 1996 4WD 4-Runner?
  56. Stock Alarm location????
  57. Leaking rear differential
  58. Its beginning to look a lot like a head gasket?! (overheating)
  59. Newbie with 02 3.4l Taco AT with shifting issue.
  60. 2001 Truck slamming into D and R! HELP PLEASE!
  61. 02 Tacoma temp gauge fluctuating and trans stopped working
  62. NEED HELP! 4wd actuator Vacuum line!
  63. 98 4runner falls on its face need help
  64. E locker rear end
  65. Smog with 7th Kit Cali
  66. 1999 4runner HVAC Knob source
  67. Removing CV with manual hubs
  68. Radiator leak. Now where to? (2000 v6)
  69. 4runner stalling in gear... Do this again please
  70. sway-a-way coilovers lifespan?
  71. 881/890 setup 10mm front spacers or not?
  72. 1999 4Runner 4WD t-case issue
  73. squeak in engine only on acceleration
  74. WTB: 00-06 TRD Tundra Coils, OME890, 5100s.
  75. New Seat Foam
  76. Jumping Time 99 T4R 3.4
  77. My time in the barrel - IAC/Low Idle Issue
  78. Tacoma running hot at low speed and idle, cools back off while at speed.
  79. replacing brake backing plates and having problems with getting my wheel flange off
  80. 97 4runner heat Not working! Need help pelase
  81. New to me 4runner overheating on long hills....
  82. 01 Ignition Key will not turn off all the way
  83. Transfer Case Issue Possible Post Front Brake Job?
  84. 99 Runner V6 AC compressor & fan losing power
  85. Buying used ifs front end
  86. tacoma
  87. 97 4runner burning rubber smell and other newbie questions
  88. Speedometer Gear Help
  89. Overheating, challenge to diagnose
  90. 98 taco 3" bilstien lift
  91. Missing Hoses? Need help ASAP
  92. Steering problems help please
  93. 17" wheels on a 96 tacoma 4x4
  94. 1997 4runner 2wd Automatic to 4wd Manual - some some help
  95. 5VZ-FE Engine Bay Clean-Up
  96. arb problem
  97. broken rear bracket on axle! (hate rust)
  98. Bilstein 5100 and ToyTec 3" lift Problems
  99. A/C Question
  100. 4wd does not engage
  101. 98 tacoma with trail disaster lift
  102. Cant beat summer in the south
  103. Variable Fuel Pressure Regulator
  104. Damp carpet - front driver's side
  105. LED Light Bar Glare? Solved
  106. 2000 4runner - No power and bad mileage
  107. 95 2.7 MAF Plug
  108. decision time...engine or head gasket
  109. 96 3.4 V6 4Runner - NAPA Premium rebuilt alternator?
  110. Pre-97 Engine Swap Into 98+ Tacoma
  111. 5VZ Replacement or Repair? HELP
  112. 2RZ-FE timing chain cover oil leak advice
  113. Advice on harmonic balancer issue
  114. 01 4runner sr5 no reverse a340f
  115. 1998 tacoma limited 4x4 suspension upgrade
  116. 2000 4 runner wont start and has a beeping sound
  117. P0325 & P0330 Diagnosis
  118. 3rd gen E-locker swap in 2001 2wd 4runner.
  119. 5vz fe flamethrower injectors
  120. 1997 4runner
  121. 4runner 5spd vs explorer 5spd -- LETS DISCUSS
  122. 4Runner or Tacoma info needed
  123. 1998 or 2000 A340F swapped into a 2001...possible?!
  124. ABS Light and p squib code
  125. 96 4Runner P0304 After Engine Warms Up
  126. Transmission Issue or something else?
  127. LX450 wheels with 231 mm brakes
  128. TRD Baja wheels and Tundra brake upgrade
  129. Ball Joints ? Wheel bearings ??2000 Tacoma 4x4
  130. HELP! trans oil in my radiator..
  131. Manual transmission help
  132. Four-pin trailer harness wiring help needed
  133. Moog parts heads-up
  134. Engine coolant
  135. light back on!!!!
  136. #5 cylinder misfire on 01 Tacoma
  137. 1997 4 runner rear susp.
  138. Need some help from real A/C experts!
  139. For Those Taco owners with New (replaced) Frames...
  140. 3.4 gets hot when under power
  141. Steering Knuckle ??
  142. Tail Light Fuse Blowing
  143. 96 3rz taco no dash light no cranking
  144. RE- engine hestation
  145. New Front bumper option
  146. 2000 4Runner reverse not working
  147. exhaust gasket help!
  148. Tacoma Upper BJs
  149. Part number EGR VSV '99 tacoma
  150. Engine misfire help!
  151. Intermitent Acceleration Engine Stall
  152. EATC rebuild
  153. Satoshi Mod 3rd gen write-up
  154. Engine hesitation
  155. what springs to get for 01 4runner road driving
  156. locked up brakes, 99runner 4x4. 3.4l
  157. Possible Electrical Issues
  158. 1999 Tacoma Frame swap
  159. My piggyback ECU (SplitSecond FTC1-E) has gone bad- recommend a replacement!
  160. rebuild tranny or drop a salvaged one in there?
  161. 99 4runner wobble/shakes?
  162. Mystery trans fluid leak
  163. help!!wheel bearing or carrier bearing or something else?
  164. Level 8 MK6 16x8 -10 clearance with Tundra brakes
  165. 1997 Ltd Massive Oil Leak-HELP
  166. fuel injectors 1998 vs 1999
  167. Braking Question!
  168. 02 bank 1 sensor 1....sensor 2? OBD2 reader help
  169. Truck wont start
  170. 1997 4Runner Drivers and Passengers Seat Replacement
  171. 4wd actuator does not operate when cold
  172. What type of Tranny Do i Have?
  173. 96 toyota tacoma squeeling in front end
  174. smoother ride
  175. 98 Tacoma 3.4L bogs down and sputters at 3500 rpm, no CEL need help!
  176. 98 Tacoma bogs down and sputters at 3500 rpm, no CEL need help!
  177. 1999 Spark Plug Guide Tubes
  178. Tacoma control arms
  179. P0420 code
  180. gear ration
  181. Manual 4WD 4Runner For Sale
  182. 2.7 header replacement
  183. Opinion's On This Product?
  184. Unusual kickdown behavior on '01 4Runner
  185. Sun roof doesn't open '99 4Runner
  186. Pressurized coolant (cold engine)
  187. 2002 4 runner cross cable boost
  188. Power antenna motor mast has too large a diameter thread!
  189. 99 4runner pictures of tailgate wiring
  190. 5VZ Cyl Head resurface measurements
  191. 95 taco 4x4 reg cab rear drive shaft
  192. My 99 4Runner limited
  193. Deckplate Mod Questions?
  194. Awful throttle response on 98 4Runner - help!
  195. 99 2wd wheel hub
  196. Timing chain last forever?
  197. Toyota 4Runner Frame Recall Campaign
  198. new guy here need little help with 98 4runner
  199. 1999 4runner limited transmission failure
  200. Radiator Leak from Over Pressure
  201. 2002 tacoma
  202. Suspension Lift/Clearance Questions.
  203. Sport Hood Question
  204. Help with door handle replacement
  205. Tell me what lift I have
  206. 2002 toyota tacoma 4x4 problems
  207. Need help with odd vibration after lift.
  208. Body lift only?
  209. flywheel
  210. Fat Lip parts schem
  211. Rear diff
  212. Sway bar bushing & ss brake lines: Part numbers
  213. Coolant/Antifreeze leak...
  214. 95 taco 2.7 4x4 clutch
  215. New Denso Radiator F/S
  216. 97 3.4 into 22re equipped 85.
  217. I messed something up... stuck in park!
  218. 98 4runner water line help needed.
  219. 2.7l 96 4runner oil leak
  220. Warm Starting Issue
  221. add-on hood scoops?
  222. Tacoma Transfer Case Dilemma
  223. Coolant leak - help!
  224. 3rd set of rotors in 6 months! help!
  225. 5VZ-FE Starting Issues
  226. NEED Help on 3RD GEN HVAC Issue
  227. My Motor Ate My Spark Plug
  228. Intermittent Starting Issue After Transmission Replacement
  229. too much rust to buy?
  230. 98 Tacoma Engine replacement help request
  231. '98 2.7 4runner hesitant.
  232. Higher Idle Wanted for a 2RZ
  233. Crank, but no start.
  234. No A/C at Idle
  235. climate control
  236. trac off vsc trac how do I reset this?
  237. Oil in throttle body
  238. Replacing Rusted 99 4Runner Body Part - Don't Know What to Call It
  239. Front End Grinding
  240. A/F Sensor Question 2000 4Runner
  241. Could taking apart my rear lift gate cause my keyless entry to stop working ??
  242. 98 4runner SR5 3.4 auto
  243. Help Pick Tires for Tunda Wheels on 4runner!
  244. p1300 code, engine won't start 1998 5vz
  245. Replacement Seat Foam??
  246. 01 3.4l hard to start
  247. 98 4runner rear shock question
  248. Tacoma won't turn over and no power to fuel pump
  249. Video - Driveshaft Play, Is It Normal?
  250. radiator
