gear ration
Old Apr 21, 2015 | 05:52 PM
Streetrod19772000's Avatar
gear ration
I put the front differential out of a 1999 toyota 4runner limited in my 1988 toyota 4runner. my 88 is 410 gears and the 99 diff must not be because i have binding when in 4 wheel drive anyone who what gear ration a 99 4runner limited had for ratio? the front diff has Pink dots of paint on it and R-37 tag. any help would be appreciated. thanks.
Old Apr 21, 2015 | 10:36 PM
toyota4x4907's Avatar
How did you get the differential to work or fit?.... And why?
A limited probably had 4.30 gears.
Old Apr 22, 2015 | 03:45 PM
gear ratio
I did a 3.4 swap with auto tranny and transfer case which has front drive shaft on opposite sides so had to mount front diff out of 99 in 88. Took some ingenuity but it wasnt that bad. I also had to blend the front CV axles with 99 on inside and 88 on outside that worked really slick and was quite easy. Mounting the diff wasnt that bad either. Truck has 3 inch suspension lift otherwise it wouldnt have worked. It all turned out beautiful except for the different ratios. I now have a set of 4.30 gears ordered for the rear of the 88 and that should solve everything!! I hope!
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
