95 taco 4x4 reg cab rear drive shaft
Upon take double cardon joint apart the grease fitting that goes to the center bearing. It was broke off where can I get another cause as of now all the grease is getting pushed out and won't last long
Use an E-Z out to remove what's left of the grease fitting. Any auto parts store will have replacement grease fittings. You may have to buy an assortment as I can't recall the size if that fitting, or if you can get a big enough piece of the old fitting you could match it up.
Colington
10-12-2015 05:41 PM
cchinny
06-25-2015 08:11 PM
