Replacing Rusted 99 4Runner Body Part - Don't Know What to Call It
Old 03-19-2015, 04:43 PM
toyotapanda's Avatar
Hello All
I'm brand new here. There has been rust accumulating on the left rear body panel above the left rear wheel (see attached picture). I have been looking at replacing it, but I don't know what the body part is called. Does anyone know what the panel is called and where I can buy it? I've tried rear quarter panel, quarter panel, rear side panel but to no avail.
Is it better to sandblast the rust out or replace the entire panel?
It's a 1999 Toyota 4Runner SR5 V6 AWD in dark green for reference.
Old 03-19-2015, 04:54 PM
slacker's Avatar
it is a 1/4r panel ..
I believe it's only available at the dealer or used ...
I have been searching for a good candidate to make moulds from , but so far to no avail
Old 03-20-2015, 03:38 PM
TheDurk's Avatar
61612 PANEL, QUARTER, LH
61612-35901 1
61612-35902 W(QUARTER WHEEL OPENING MOULDING)
Pretty sure it's the top one.
http://partsfactory.camelbacktoyota....ota/6161235150
Old 03-21-2015, 01:34 AM
wyoming9's Avatar
Red face
It would depend just how fussy you are.
Me I would wire brush hit it with some Hot Pink paint and be done.
I have lots of hot pink paint!!
Then you might plan to have the quarter panel replaced and paint the whole vehicle .
Old 03-21-2015, 02:13 PM
Nervo19's Avatar
The chrome trim on the wheel wells collects dirt which holds moisture and causes rust. Take the trim off. You are at a point where it is still easy to fix without welding a new quarter panel. Hit it with a wire wheel, prime and paint as Wyoming9 said. There are online sources for spray cans of factory matched paint.
Old 03-21-2015, 06:03 PM
slacker's Avatar
it is not just the moulding , that causes this .. but also the inner tub . 2 steel parts together with no barrier . most I have seen are from the inside out .
replacing the steel with more steel is only a "band aid" .. (IMO) and will rust again . thing is , most people don't keep it that long to notice
zd92655
03-06-2022 12:58 PM
voiddweller
19
05-02-2016 09:10 PM
vasinvictor
01-20-2016 12:39 PM
infinityisfive
06-16-2015 06:51 PM
JaredL
06-16-2015 04:47 PM
Quick Reply: Replacing Rusted 99 4Runner Body Part - Don't Know What to Call It
