96 3rz taco no dash light no cranking
Old May 14, 2015 | 08:37 PM
lupatrol's Avatar
ok helped a friend with his 96 tacoma he need a timing chain done pulled it all apart put it all back together and i have no dash lights it dont atempt to crank nothing radio wont even come on but the key ringer works head lights work but no tail lights theirs a single wire plug but no on can identify under the distributor and i cant find a single place of it to go its lined in with the oil pressure sensor im kinda new to these 3rzs ive always ran 22rs if someone need a pic of the plug i can try to post a pic
Old May 15, 2015 | 12:01 AM
wyoming9's Avatar
Red face
Sounds like you had a fusible link open.
Battery negative cable off while doing the work??
Grounds not hooked up correct.
I doubt one wire not connected would cause all those electrical problems
Old May 15, 2015 | 07:46 AM
toyota4x4907's Avatar
Did you drain the battery when you took it all apart? Left the radio going for music while working?..
ashersullivan88yota
Jan 18, 2022 05:37 PM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
redneck17
Jul 17, 2015 07:44 PM
Johntom240
7
Jul 13, 2015 12:18 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
