2.7 header replacement
Old Apr 21, 2015 | 07:02 AM
Sam hain's Avatar
I noticed I can hear a ticking sound when motor is starting after sitting long enough to get cold. Once warm it goes away. I found this thread on here: https://www.yotatech.com/forums/f2/o...l-pics-157752/
So I ordered the header for an 01 and the gasket kit from Toyota dallas and its suppose to be delivered tomorrow. Just curious if there's anything I need to know (not covered in old thread above) to make install any easier?
thanks,
Old May 7, 2015 | 11:16 AM
Sam hain's Avatar
I ended up being lazy and let a shade tree mechanic do this swap and I'm very pleased with how the truck runs now. Motor noise in the cab is very quite now, noticed a small increase in power especially when running in to high a gear and the trucks starts to bog. Before I'd have to down shift, now it just pulls itself back up to "normal" rpm range. As I suspected the old cast manifold was cracked in between cyls 2 & 3 and the o-ring gaskets where the manifold meet the collector were burnt up pretty good.
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
1994toyota
Jul 17, 2015 03:03 AM
Coreyr384
Jul 10, 2015 11:13 AM
