PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Need Rear Axle Assembly
  2. Here she is, let the mods begin!
  3. Which optima yellow top?
  4. 33" x skinny x 16"
  5. 255/75/16 Rig pictures
  6. Need a hand with my ABS light being on, Anyone?
  7. 3rd Gen Headliner Cleaning
  8. Weight of stock wheels?
  9. Bobbling Window??
  10. Mystery Red Button
  11. Tax submittal .... ?
  12. Good Buy?
  13. grill pics for fr3533
  14. 99' Tacoma fabtech 6" lift Question
  15. Anyone have a partsheet list? I broke a front sway bar hanger.
  16. Stud Removal - Front drivers side
  17. need ideas for rear bumper
  18. Stock or Modified Intake Pros & Cons
  19. Just Lifted my '01... thinking about taking the rear springs back out (too stiff)
  20. Knock sensor error
  21. Recommend a Truck Cover?
  22. Need advise on 4runner lift
  23. Door Mods
  24. Fading Door Trim
  25. I did it its gone!!!!
  26. Installing Cold Air Intake w/stock MAF
  27. will these tires fit?
  28. decoding my vehicle info
  29. Toytec vs. ss lifts
  30. Axle Questions
  31. Engine Failure - Blew A Rod 2001 4runner
  32. '97 Limited Runs Rough at Low RPMs
  33. 99 4Runner won't idle
  34. 99-02 Grills Fit 96?
  35. Another SS 1.2 installed w/ Tundra rims.
  36. What's it Worth
  37. How long do the stock rear springs last?
  38. Clean out your A/C fans!
  39. Factory Roof Rack
  40. Wiring up Leer camper cover??
  41. just got a runner--PICS--
  42. Radio light out-searched high and low...
  43. Gears?
  44. cut out flares help
  45. Tacoma, Tundra and 4Runner can they be swapped?
  46. battery question..
  47. i need some opinions...
  48. 2000 limited, dash lights don't work after accident
  49. Gas Mileage in 02 Taco 3.4L - 3.46 Gears??
  50. New sound - and not liking it
  51. Towing Power?
  52. Lubricating power windows?
  53. Need help with 96 3.4 4x4
  54. oil filter help!!
  55. TJM, fastest & cheapest place to get one from??
  56. Think You Have The Best 3rd Gen? Post it up
  57. Opinions on batteries - Optima Die Hard
  58. Aussie Taco & Next gen Taco??
  59. How do you remove the trim at the bottom of the rear door window?
  60. strange rear end and or parking brake problem
  61. Got in an accident today, pics of carnage
  62. Share my P0301 DTC experience
  63. street spacer lift questions
  64. 4runner center consoles, any interest?
  65. Timing belt done
  66. rear right brake locking up.. help!
  67. Check Enging Light/VSC Off/VSC Trac
  68. Help!
  69. REVO's are Awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  70. Front end question
  71. When to use ECT PWR
  72. Weird temperature issue
  73. Transmission drain plug
  74. Trail Gear Sliders Installed w/ pics
  75. Finally Got my truck!!!!
  76. U joint ?
  77. What kind of gas mileage should I get
  78. Taking my T4R back for noise and smell, any ideas of where to look?
  79. 98 4runner motor problems
  80. 3" body lift sliders (NEED TO FIND)
  81. LED Cluster Install Question
  82. just got a runner!!
  83. Gas gauge reads complete backwards, need to fix ASAP!!
  84. WANTED - Center Rim Caps
  85. Header/Exhaust Manifold Torque?
  86. Thule Racks
  87. How do I change a Fuel Injector
  88. 4runner Lifts
  89. Toyota Dealership tried to rape my friend.
  90. What is the SR5 package on 95 -97 Tacoma
  91. GM Top End Cleaner
  92. newbie's 99 4runner pix
  93. When ordering brake pads
  94. 98 4runner project with **pics**
  95. Looking for advice on wheels
  96. Are LC coils progressive?
  97. Stock tie rod lengths?
  98. crank bolt
  99. Bolt on D-Rings - Good idea???
  100. Differential and Tcase Capacities??
  101. P vs. LT
  102. 97 4Runner Catalytic Converter Stolen - Advice on Replacement
  103. special tool for timimg belt change
  104. ??s concerning antenna in pasenger rear window
  105. New to the business.
  106. 99' 4runner SR5 4wd!!!!!!!!!!!!
  107. Bilstein shock question...
  108. Another code p0171 thread (searched hard and tried many things)
  109. New Wheels
  110. Chrome rear bumper got dented, replacement?
  111. Intake Silencer Removal Question?
  112. Clutch Issue
  113. Which spring and spring rate?
  114. So pissed at my dif drop
  115. Removed Antenna - Not Replacing - Hole - Cover with Grommet Bumber?
  116. Driving lights/Fog lights
  117. Duralast Brake Shoes
  118. Roof Rack and what Can it hold, RTT?
  119. I have searched but no luck so please help
  120. Bilstein 5125 shocks
  121. question about tire size
  122. FINALLY...lifted my 4runner
  123. Transmission Question - 02 4R AT
  124. 2003 tacoma for sale alabama
  125. Replacement keyless
  126. 98 sr5 alarm
  127. Clear corner LEDs: White vs. Amber
  128. CEL Poll...
  129. top plate spacer
  130. 22RE to 3RZ?
  131. Cxrazy's Custom Bumper - PICS
  132. pp coil springs
  133. How far can i crank SAW coilovers safely?
  134. my new CB & antenna install
  135. 99' Herculining Fun
  136. My new '99 LTD leather seats for my '98 SR5
  137. 3 Gen 4Runner Sliders
  138. '04 Tacoma - Steering Clunk
  139. Weird fill up issue - others?
  140. Automatic to 5-Speed Manual Conversion
  141. For those who have done the cup holder mod - what did you do with the old cup holders
  142. Pics Sonoran Steel 7.1/7.2/ OME 891
  143. 2wd to 4wd conversion complete
  144. Starter? Or Electrical Gremlin?
  145. power antenna relay?
  146. drivetrain stutter, trans problem? 99 runner 140k, louisville area
  147. digital climate control in a 02 sport?
  148. hatch door latch handle broken - can't open
  149. Nice 4runner but with weird options..what you think?
  150. Lights from Bling Lighting
  151. Finally!
  152. sliders...yes or no?
  153. I need somebody near Louisville/Cincy to weld sliders on
  154. Definity Dakota M/T Tires Purchased
  155. buying 305/70/16 MTR's..what steelies work?
  156. Looking for 3rd Gen Body/Body with blown motor.
  157. What happens when you never adjust the valves
  158. Buying a 99 runner
  159. Armorology bumper and Trail Gear sliders install (PICS)
  160. Look what i did today, painted the grill, looks sweet
  161. FX35 bi-xenon Projector retrofit in a 3rd Gen 4Runner
  162. Ridin' Dirty....No...My truck is actually really dirty
  163. Anybody know of any tire sales going on?
  164. Impact of tire weight
  165. Tire Gate FOR SALE!
  166. wheel well plugs
  167. MPG increaser ??
  168. Totaled My 4Runner...
  169. Inner Fender Plugs
  170. Update on my '00 4runner with pics
  171. Left/Right Hand Cylinder Heads all the same?
  172. dust caps on the rear drums?
  173. aux 12v plugs
  174. Should I take my brushguard off?
  175. 3rd Gen 4Runner gettin 35's!!
  176. Smashed
  177. CRAZY fuel gauge
  178. center caps on 98' 4runner
  179. New Tires and Wheels came in today! (PICS!)
  180. Supercharger help!!
  181. Does the bolt pattern line up for a '98 4Runner and '07 Sport Edition 4Runner?
  182. wHAT WAS THIS FOR??
  183. Oil leak around oil filter
  184. Scored some JDM Vent Visors!!
  185. Good looking replacement Radio antenna
  186. 98 4runner v6 - Electrical problem Car will not turn over
  187. Tie rod replacement
  188. How to get a smoother ride on my '98 4Runner
  189. Passenger side tear down write-up ? / Stick back foam
  190. 1999 Toyota Tacoma $$$3500!!!
  191. 3in Lift and tires installed (PICS)
  192. Intake Silencer?
  193. Satoshi done!, different mesh, pics, etc
  194. How many cans?
  195. Rear and front diff gears!! help.
  196. Cylinder Head Spark Plug Tubes
  197. Exhaust system for longbed Tacoma?
  198. 2002 4Runner ?'s
  199. Any tips before i install my lift this weekend?
  200. Picks of my old 85 4runner and new 2000 4runner
  201. I wanna steal a FJ80 e-locker!
  202. 1999 4runner lift questions
  203. DC-1 polished wheels
  204. Water Pump and Timing belt @ 70k miles
  205. Aftermarket Wheels
  206. Brake Question....
  207. Differential Swap Questions
  208. oil filter relocation kit
  209. push button 4wd question
  210. In-dash Scan GaugeII
  211. 2000 Tacoma 3.4L heater hose identification
  212. oil leak
  213. Can't get my dif drop in!!!!
  214. Got a 2000 limited 4runner on 3/21 w/o any service history...what do i need done?
  215. Hella H3 Yellowstar Bulbs
  216. Help please
  217. do 33's fit
  218. Front End Leveling
  219. HELP Wheels dont fit on 97 tacoma
  220. Which skid plate should i buy first?
  221. Trading up for an 2000.....?
  222. Skid plate opinions
  223. How do i know which engine size i have?
  224. High pitched engine noise
  225. Making custom rock sliders, need some info!
  226. Lift kit Dilemmas! 02 4Runner
  227. Rough running engine, Flashing CEL, pulled codes
  228. Transfer Actuator?
  229. pics of 5Vzfe
  230. 2002 4Runner Sport 4x4 Front Brake Job
  231. DIE HARD This is why I own a Toyota truck
  232. Help
  233. is it the fuel pump
  234. swapping doors on 97 xcab Tacomas
  235. Extra Gas..Available Options
  236. Rear axle shaft broke -- Now what?
  237. Need info on power antenna repair
  238. true dual exhaust ?
  239. 97 4Runner, 215,000 miles... flashing check engine light
  240. Whats a good temp gauge to buy?
  241. 4Runner Trailer Brake
  242. What shocks give the best highway ride on the 4wd 4runner?
  243. Clink/ping noise from right front
  244. Loud fan noise from engine
  245. New wheels for stock 99 4runner - best tire size option?
  246. 01 4Runner ash tray light...
  247. CLUNK in steering 2003 taco
  248. elocker problems. What did I do wrong?
  249. anyone running rock crawler 152's or alloy 1059's
  250. help w/ tires rubbing upper A-arms
