Toytec vs. ss lifts
Old Apr 8, 2008 | 10:41 PM
michalik_piotr's Avatar
Toytec vs. ss lifts
Besides the price, opinions? Which is better and why? Trying to decide and maybe budget for one. Thanks
Old Apr 9, 2008 | 04:18 AM
emptypockets's Avatar
Either is a good option, but the SS systems are specifically designed for trail performance. Avoid the Toytec coil spring spacer kits. Spacers just aren't a good long term solution. Their coil lift kits will be fine though.
Old Apr 9, 2008 | 06:54 AM
hross14's Avatar
SS-It is a strainght forward kit and built very well. you will have no surprises when you put it in
Old Apr 9, 2008 | 07:10 AM
j-man's Avatar
i just put in the SS #1 kit with the cruiser coils and everything else he has for the rear in my 2000 4runner, and put some sway a way's 2.5" in the front along with some 285's and ill tell you what - its the nicest darn riding 4runner i have. Im going to switch the other 3's rear suspension to his - the ride is sooo smooth, yet tight - hard to explain but its hands down the best rear lift for any 4runner.
Old Apr 9, 2008 | 10:58 AM
psraff's Avatar
I'm thinking my shocks and springs may be getting weak so I was researching the SS lifts... For the 1.2 it states: "At a bare minimum, if you have a stock rear bumper, you need to have at least a Class III trailer hitch installed with the complete stock rear bumper along with a set of functional rock sliders. "
Why do we "have" to have that? It's not a big deal, I have the hitch, and the bumper and the sliders are fairly cheap. But what's with the lift that need the hitch and the sliders? Or am I just misreading it?
Old Apr 9, 2008 | 12:16 PM
montana nate's Avatar
I think they could be talking about the weight, stiff springs without any weight on them are going to ride rough ...... they are designed to carry a certain loading
Old Apr 9, 2008 | 01:04 PM
psraff's Avatar
Ahhh Good point. Makes sense. Thanks!
Old Apr 9, 2008 | 05:09 PM
The LC's are not stiff springs. The reason they call for the additional weight in the rear is to "tame" the amount of lift you'll get from them. Without the hitch and some extra weight in the rear, expect ~4.5" from the LC's. Mine have settled from 4.25" to about 3.75 now...and that's after a year of use and abuse.
You'll find that the LC's are one of the softest riding and best articulating springs you can put on your Runner. The OME's on the other hand are very stiff!
Old Apr 9, 2008 | 07:24 PM
d0ubledown's Avatar
ome's are stiff. never ridden in an SS lift, but my friend had an '00 with the downey coilover kit with billies. it was quite plush...very nice ride....id say about as plush as stock with a touch firmer dampening to it..
Old Apr 9, 2008 | 07:52 PM
Albuquerque Jim's Avatar
The SS kits are tried and true. Steve is always upgrading components to refine his products to a superior level. You won't be disappointed.
Old Apr 9, 2008 | 08:33 PM
thmpr's Avatar
My SS 7.2 just arrived and so stinking excited. Will do it this weekend!
Old Apr 9, 2008 | 08:37 PM
Hmmmmm, I still have the original OEM springs from my FZJ80, I was thinking they would give me more lift and stiffer then I wanted, but since they are already broken in, I may have to give them a shot ...... so if those are out back, whats a good pairing to them up front?
Old Apr 9, 2008 | 08:51 PM
Careful, you have to use a certain coil, some years are way off.
www.sonoransteel.com
Old Apr 9, 2008 | 08:55 PM
Do you know what year? Mine are off my 97' FZJ80, I have both the front and rear coils
Old Apr 9, 2008 | 08:56 PM
Sloan's Avatar
does anybody know the difference between toytecs coils vs. the ome ones?
Old Apr 9, 2008 | 09:07 PM
rdang's Avatar
I'll have to agree with j-man, I installed the SS 1.1 recently and the ride is much, much better than stock - that's with no extra weight from bumpers... and the flex is outrageous!
Old Apr 10, 2008 | 07:54 AM
hross14's Avatar
Took at look at the Toy Tec lift--i wouldnt go that direction. Do it right the first time and be pleased instead of seeing me out there wheeling and asking you WHATS WRONG? No just kidding--but do it right and it wont regret it. I cant tell you how many times i purchased a cheaper this or that and ended going back for the more expensive this or that.
suppra87
Jul 15, 2021 05:15 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
AkitaDog
Sep 3, 2015 09:01 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
