01 4Runner ash tray light...
Old Mar 22, 2008 | 07:22 AM
bobs01sr5's Avatar
How the hell do you replace it ...or can you?
I managed to break the glove box light I wish they would make them easier to replace the stinkin bulbs !!!
Thanks !
Old Mar 22, 2008 | 08:43 AM
Godzilla's Avatar
Remove the ashtray.
The metalish sliding mount will be left. This is connected to the dash via 2(or 3, cant remember) screws that are annoying to take out. You need to crouch and contort to see them. Once out, the guide will side out and you will see the light connected to the guide.
Old Mar 23, 2008 | 07:03 AM
bobs01sr5's Avatar
Thanks for the help and what a #@%*& to get in there !!!
Old Mar 23, 2008 | 10:17 AM
Fo_SheeZy's Avatar
Originally Posted by Godzilla
Remove the ashtray.
It's easier to pop out your comsole and change it that way.
Old Mar 24, 2008 | 04:19 PM
atl4runner's Avatar
what kinda bulb is that you stick in there?
Old Mar 24, 2008 | 05:32 PM
Fo_SheeZy's Avatar
It's a #74.
Old Apr 18, 2008 | 05:22 PM
bobs01sr5's Avatar
Stinkin thing is small and not cheap either
Old Apr 18, 2008 | 09:57 PM
Fo_SheeZy's Avatar
Haha yeah.
Old May 14, 2025 | 12:49 PM
Charlieg's Avatar
Remove and replace ashtray light bulb
First it is a #74 bulb Amazon has them box of 10 bulbs. Enough to do the complete dash board lights. I have a Base 2000 4Runner, it is wired for and had the burnt out bulb. I used long needle nose pliers, the bulb pulled straight out, no twisting or pushing in. Just grip the bulb gently with the needle nose pliers so it doesn’t slide off the bulb as you pull straight out. Put new bulb in push straight in. You can feel when it’s seated in correct. Again no twist or turn needed. The ignition does have to be on and lights switch on for the bulb to come on. It’s designed specifically for nighttime use. Simple Toyota set up. I hope this helped someone out there.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
