Removed Antenna - Not Replacing - Hole - Cover with Grommet Bumber?
Old Apr 1, 2008 | 07:29 PM
416kid's Avatar
I have a 1999 4Runner. I recently removed my power antenna and do not want to replace it, so I am left with a hole. Any suggestions to cover the hole? Grommet bumper?
Old Apr 1, 2008 | 07:32 PM
scuba's Avatar
exactly why would you want to run without an antenna ?
Old Apr 1, 2008 | 07:45 PM
416kid's Avatar
The teeth on the toy antenna broke, so I decided for a new look. I mounted a new antenna for a CB/AM-FM/Radio on the rear bumper. I have seen random pics of rigs with no front passenger antenna that have been capped off, so I am sure someone has found an innovative solution...
Old Apr 2, 2008 | 07:20 AM
eric-the-red's Avatar
Make the hole biger and use it for a snorkel
Old Apr 2, 2008 | 08:29 AM
crolison's Avatar
Not a bad idea at all. A funny thing when i put on my snorkel i was cutting the big 3" hole in my fender and i went right into my antenna mast and killed it, smart thinking on my part.
Old Apr 2, 2008 | 05:29 PM
pattycakes77's Avatar
i never listen to the radio and i have thought about buying a right fender from a hilux surf and putting it on my 4runner. since the driver sits on the opposite side, they have their antennae on our driver's side and no hole on the other side. i see them on ebay every once in awhile but you have to buy them in pairs i would assume. and, they have the side marker lights on them too so you would probably want to put the marker on the opposite fender for symmetry, or it might tip your 4runner over from uneven weight distribution that last part was a joke, fyi.
Old Apr 2, 2008 | 06:54 PM
DeathCougar's Avatar
Some early model (89-95) trucks had a radio delete option, and in the place of the antenna was a plug. That may work for you, but they are harder than heck to find.
Old Apr 2, 2008 | 07:34 PM
07sbock's Avatar
Can I buy the little rubber thing and shroud and the screw on nut from you. Mine got loose and lost it in a car wash!
Old Jan 4, 2010 | 01:26 PM
94greenrunner's Avatar
You could just leave the antenna on there and loose the motor, i did that because the motor would go every time i turned the car on or off and it was buggin the crap out of me. so now i have the antenna on and can pull it up and down manually, but i always just leave it down. works for me
Old Jan 4, 2010 | 04:44 PM
Midget96's Avatar
A rear window wiper plug for an EG Honda Civic might work. I used one on my old Integra when I ditched the retarded automatic antenna. Cheap from the dealer (either physical or online) and powdercoated black. Worth a shot...
Avenged
Jul 9, 2015 07:55 AM
ItsJustD
Jul 7, 2015 07:49 AM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
