How do i know which engine size i have?
Old Mar 24, 2008 | 12:17 PM
avryco's Avatar
its either a 2.4 or 2.7 any easy way to figure that out?
Old Mar 24, 2008 | 12:22 PM
sleepy970's Avatar
Most likely you have the 2.7l under your hood. There should be a sticker under there that will say what kind it is.
Old Mar 24, 2008 | 12:27 PM
mr_schuster's Avatar
I don't know of a 2.4L in a Tacoma.
2.7L or a 3.4L
Old Mar 24, 2008 | 12:35 PM
avryco's Avatar
they definitely make a 2.4 and a 2.7
Old Mar 24, 2008 | 12:40 PM
netwt12's Avatar
If it's a 4x4 or prerunner it's a 2.7L. if it's a standard 2WD it's a 2.4L.
Old Mar 24, 2008 | 12:41 PM
BluYot's Avatar
The 2.4 is the precursor to the '95.5 and up 2.7L. 2.7 is found only in Taco's...at least here in Canada whereas the 2.4 22RE is found in the straight-up mini trucks pre '95.
Really eh?....2.4 in the 2wd's? Had no idea...good to know, thanks.
Old Mar 24, 2008 | 12:51 PM
avryco's Avatar
its a 2wd prerunner....
Old Mar 24, 2008 | 12:53 PM
crolison's Avatar
by the looks of your picture you have 6lugs which means 3rz = 2.7
only the 5lug mini tacos come with the 2rz=2.4
but this has been stated above
Old Mar 24, 2008 | 12:54 PM
Matt16's Avatar
2.7L. You can confirm this by checking on the firewall and it should say 3RZ-FE.
Old Mar 24, 2008 | 01:01 PM
avryco's Avatar
cool thanks guys!
djpg2000
Nov 11, 2020 04:56 AM
Whatever123
Sep 30, 2015 12:12 AM
Sep 4, 2015 09:27 AM
Yotoder865
Jul 9, 2015 07:51 PM
