oil leak
Old Mar 24, 2008 | 10:49 PM
86toysr5's Avatar
oil leak
ive looked and dont see wheres is coming from but my 2.7 is leaking oil on the passenger side. it has a new pan gasket and filter but its higher then the pan and its not the pan leaking. the passenger side would be the side the exhaust is on. i was told to try the oil sending unit or something like that. it only leaks when the engine gets hot. i havnt had time 2 look i just got done working 13hrs and gotta be up in 6 hrs to go work 8more. thanks for any help
Old Mar 25, 2008 | 07:07 AM
BajaRunner's Avatar
Sounds like the valve cover. I could be wrong. The 3.4L have had problems with that but since you've got a 4 cyl, it might just be coming from the passenger side?
Best thing to do is clean the crap outta it with engine cleaner. I do not recommend the engine bright stuff... it does work, but, its really nasty crap you don't want it going into the drains or in the earth. There are some more "natural" stuff that doesn't stink up your driveway and polute quite as bad.
Then you may be able to track where it is coming from easier.
Old Mar 25, 2008 | 06:10 PM
86toysr5's Avatar
its not the valve cover its coming from under the exhaust manifold. im trying to sell the truck and its one problem after another. almost had it sold then broke down and trying to sell it now and now this oil leak
Old Mar 25, 2008 | 06:19 PM
jason191918's Avatar
Did you check the sending unit?
Old Mar 30, 2008 | 10:58 AM
86toysr5's Avatar
ok i check and its not the sending unit
the piece taht the oil filter screws on to is it bolted or casted to the block?
Old Mar 30, 2008 | 09:30 PM
86toysr5's Avatar
bump up
Old Mar 31, 2008 | 07:38 AM
BajaRunner's Avatar
Where is it coming from?
Take some pictures and post them!
Old Mar 31, 2008 | 10:38 PM
86toysr5's Avatar
from by the oil filter the piece that goes 2 the block
Old Mar 31, 2008 | 11:14 PM
etan's Avatar
oil filter gasket? or is there an adapter piece missing. that's what happened on my 2.7
Old Apr 2, 2008 | 09:09 PM
86toysr5's Avatar
does the oil filter thing bolt to block or is it casted that way
Eggslinger
Jun 8, 2019 03:32 PM
Ladythump
22
Nov 9, 2015 08:53 AM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
