- 5VZ-FE Valve shims diameter
- 4WD Indicator Blinking for no reason
- Advice on 420 code and replacing O2 sensor
- 3.4 v6 5VZ-FE Thermostat
- 96 Paint Code Help Needed
- 4Runner Hates the cold misses the south!!
- Just a few leaks in my exhaust
- 97 2.7L 230K Tacoma $4,500?
- 1996 4runner headliner change
- Moog Coil Springs for a 98 Tacoma
- Extreme amounts of moisture in Air Intake
- All these transmission drain/flush/cooler threads!!!!! (Let's nail this coffin!!)
- 2.7l Stumbling and running Rough help
- White Paint
- Registered in VA
- what amp fuse goes where
- Toyota OEM parts source
- Vibrating front end, replaced rotor's still doing it.
- Trouble starting 2000 4Runner
- 02 4Runner 4wd wont disengage.
- 99 4runner Puttering and Shaking.
- Crazy Oil leak HELP!!!
- 3rd Gen Knocking noise solution
- wheel bearing confusion
- lock cylinder removal
- Alignment and uneven braking (and wheel cylinder woes)
- '99 3.4L V6 4x4 T4R Air Intake Hose??? Where can I find one?
- 2004 Tacoma, 2.7 Starter Issue
- 4Runner Won't Start - Clicking Noise in Engine
- TRD supercharger rebuild.
- 98 4runner high idle after TB cleaning
- 99 4Runner SR5 Sunroof Resto
- Stereo shot?
- Fuel Filter Install (relay missing?)
- MAF sensor interchange?? 3.4
- First maintenance experience
- 99 Tacoma 2.7 starts missing as fuel level declines
- Ball joints
- 5VZ-FE Fan Pulleys
- Looking for some good looking sliders....
- Engine and Tranny Swap (together)
- Icon upper control arms
- Camburg/Sway-A-Way 2.25 coilover for 96-04 tacoma rebuild!
- poor gas millage and gas smell, with a p0171 code
- Buying a 97 4runner 5speed for $5999
- 99 Toyota 4Runner Limited 4x4 - Replace Engine
- 99 4 runner won't engage 4wd
- Tacoma or 4runner? Need help
- Squeaking or squealing noise coming from back of truck
- Another axle bearing write-up 98 4runner ltd
- 1997 4runner 2.7L 4 cyl 2wd
- 2001 Tacoma high mile question
- Broke Student looking to work on 4Runner
- 3.4 overheat!
- 3rz starts, runs normal 3 seconds, then dies instantly. how did I do it?
- 2002 4Runner Rack and Pinion Leak...
- 1996 4Runner rear end noise, video included
- Door parts/clips - what have you had to fix?
- 2000 SR5 with "clunk" noise when turning
- how to change air conditioner filter on a 2001 Toyota Tacoma
- Uses water when outside temp is cold
- Operation: Re-build The PATYWGN!
- 1997 4runner
- Vibration in 2000 4runner
- 96 ball joints
- 96 4runner Factory Service Manual
- Rims from Sequoia
- Cylinder(s) running hot?
- 3.4 Evap removal question.
- Rear Window
- Gaskets and misc parts
- How's your Tacoma in the snow?
- 1995-2001 Same Topper Size?
- newb intro
- h1157 bulb heat issue?
- 96' 2.4L Fuel Pressure Regulator
- 300km to a full tank of gas in the 4runner ?
- Jump start with cables crossed now no power at all
- 97 4R vibration in floor, searched, no results that match
- 1999 Ltd 4runner
- driver rear ABS wire break
- 3rd gen 4Runner Skid Plant??
- noob locker question - what to get?
- 1998 4Runner Shifter Bushing and Seat Part (Canada). Can I use 2nd Gen Part?
- electrical question
- Quick ARB Bumper Question
- Surging/Thrusting Problem Under Acceleration
- 97 fuel filter
- 4Runner/tacoma 3rd members interchangeable?
- Hello and intro.
- new clutch sounds/feels bad
- Look what I got in the mail today!
- Oil on airfilter
- Tokico Treckmaster Shocks Discontinued
- who need a plate bumper for 2in body lifted 4runner?????
- steering rack bushing replacement
- 96 tacoma 3.4 not hiting on 1,3,5
- Hello and intro;)
- Traction control malfunction?
- seatbelt/carseat issues
- locking dif
- Rusted brake line section. Insitu repair without removing entire line?
- truck Stalls Out after fuel fill up
- Can a overheating tranny cause coolant loss?
- who has ome 891 rear lift near 91748
- Bypass Actuator on 3.4 TRD supercharger slow to close?
- 02 Tacoma 2.7 with low and rough idle
- 97 4rnr rear window problem
- 97 3.4 toyota 4runner threw egr code???
- Very fishy starting issues?
- 3.4L engine build?
- ac/heat cluster lighting
- Timing belt woes
- Clunking and shaking when applying brakes
- 96 4runner
- Starter Relay Location (solenoid contacts already replaced...)
- New to me 96 2WD V6 4Runner with a few questions
- 97 Runner Transfer case issues?
- Rebuilding altenator
- V6 cam seals
- 4Runner start problem
- Nube questions about valve job/valve repair
- 3.4 Starters AT/ Manual Difference???
- Vacuum lines
- Rock sliders
- bad transmission???
- CD Deck install issues
- 5VZ-FE amp draw?
- Crank Pulley Broke - Need Ideas - 99 4R 3.4
- Boost Gauge Installed Wrong?
- O2 sensor cleaning?
- Transmission Acting Weird - 2002 4Runner
- Help! Can't shift into drive and Trac&ABS lights on.
- 2000 Tacoma clutch
- Won't start: 95 Taco 2wd has fuel and spark, ideas?
- Intake manifold advise
- Vin help please
- Aftermarket Tach on 3.4?
- 01 Tacoma Cold weather gear oil??? And manual tranny remote start??
- fuel trim code p0170 and bed fuel economy
- '04 3RE-FE Name This Electrical Connector
- mystery compartment in rear cargo area
- TRD rear locker
- 97 4runner rear heat not working
- 2000 4Runner, significant lean after installing shocks and springs!
- Is Mobil 3309 ok???
- Evap system Not Ready
- Monroe strut-mates & Billy 5100's
- transmission trouble...SOS!
- Brake Light on Dash Intermittant
- UCA: Light Racing
- 2001 4runner 4wd light flashing
- Master cylinder/brake booster problems and bleed question
- Recovery/Pulling-Out Other Vehicles - 4WD??
- 96 4runner door wont open????
- 4wd question
- 2000 Air Mix Control and Servomotor
- Tacoma brake upgrade....
- oil leak
- Snow virgin trip to Tahoe (pics)
- 98 taco auto 4x4 which delco o2 to buy?
- LC coil lift on, now I cant stop feeling like im hopping around.
- 98 3.4L manual transmission - How many bolts?
- 96 runner factory wheel well gap
- Starting Problem on 4runner
- 4runner + water = 420
- 99 4runner hesitates. No code.
- Is this totaled?
- 98 4runner choke out, cleans, works, 6 months later chokes out again?
- Smoke coming from the intake!
- 2002 vs 2003 FSM
- coolant line in valley of 3.4
- Starter spins doesnt engage flywheel
- Fuse box relay
- Tight Steering, Won't Auto Center
- Doors automatically unlock when engine on
- 98 toyota tocoma
- '97 max load
- Air/Fuel Sensor: easy way to save $350
- Alternator... but not really?!
- Dual t-case options
- fuel pump going south?
- 3rd Gen 4Runner A/C and heater symptoms
- Non-ABS axle shafts in ABS housing?
- engine failure at 5500 rpm
- Compression shot in 1 cylinder - Burned Valve? HELP
- total ball joint failure
- Fuel Maps for '97 3.4L S/C, 305CC/ Walbro 190
- 2001 Tacoma Blown Front Diff?
- 98 4unner 3.4L - Trouble in O2 sensor land
- 98 a340f in an 02'??
- Phoenix Mechanic
- Water Pump...3nd Time is a Charm
- Addicted offroad bumpers
- 4.56 Diffs at Rathe's in Colchester,VT
- 2000 4runner - camshaft position sensor resistance?
- 3.4L seems like it hits rev limiter
- Oil leak diagnosis
- climate control questions, a few issues
- Towing capacity?
- 2rz missing when cold
- Couldn't stay away.... $340 4Runner
- 3rd gen steering wheel question
- Picking up my 3.4 5 speed 4 runner in the morngin
- 99 Wiring into 1996 4Runner Problem
- Possible Mods
- Heater core flow direction - arrow on control valve?
- looking for 97' 3.4 EWD
- 2000 4runner brakes pulsing on startup
- Four wheel drive problems
- Engine Swap Issue
- 2001 4runner toytec lift
- tacoma with crew cab and manual?
- 3.4l issues
- 3rd Gen 4Runner or Tacoma for College Kid
- School me on the 96 4Runner
- Why would an inner tie rod fail after 22500 miles? Help Please!
- R150F manual transmission to NP203 transfer case
- 3.4l help!
- 5vzfe wet plugs one side
- open door switch inop
- 96' runner; unequal braking
- Low Idle / Bad Battery / Bad Alternator ???
- Removing 3RZ wiring harness.
- New Tires, looking to move up
- 2.7L Stalling, Cutting, Runs Rough
- '98 Toyota Tacoma misfires (random and non companion cylinders)
- Front Strut 2wd 96' 4 runner Problems
- 99 4Runner Rusted Frame Options? Part Out?
- New Vibration's
- Vibration with acceleration
- Front Wheel Drive 4Runner
- rims for 3rd gen 4runner
- 96 4runner 3.4 4wd front wheel bearing help
- Throttle cable adjustment
- Poor gear engagement when running--no problem when truck is off
- Need troubleshooting advice for noisy rear end
- HELP!! Stranded :(
- will a clutch purchased for a 3.0 fit the same for a 3.4?
- After New Fuel Injectors, Motor Won't Turn Over? -- Help?
- 99 4runner slow uphill only
- Which brand Fuel Filter
- HELP Bent skid plate front support - best way to fix?
- Need a new rear axle
- Need a part number asap!!!
- Intermittent compression issues
- Ignitor failure?
- Please Help!!! 99 4runner Limited 4x4 transmission Problems
