Oil on airfilter
Old Jan 11, 2013 | 03:17 PM
breugel's Avatar
Oil on airfilter
3.4 has 191k on it and when I took out the airfilter I noticed a little oil in the housing.
from what I have read it is either a pvc valve or blow-by. I was planning to do a seaf foam treatment to hopefully un stick a ring. Am I on the right track?
I have no idea of the history on this truck. I got it cheap for here and it whas not been maintained well.
Old Jan 12, 2013 | 06:33 AM
Sludge Monster's Avatar
Sludge Monster recommends that you check your PCV. easy to do and cheap to replace. Mine was compeletely shot and the valve cover passage ways to the PCV were clogged. not a pretty sight when we went to do the timing belt...
Good luck.
Old Jan 12, 2013 | 06:39 AM
breugel's Avatar
I did that to we will see... I am going to change the plugs today and clean the intake,maf and TB. We will see if the oil comes back.
The car runs good and the PVC was very dirty. I am sure it is sludgy.. What do you recommend to treat the sludge? I am not looking for a quick fix but I do not want to tear the engine down either.
Old Jan 12, 2013 | 06:54 AM
Not sure how deep you wanna go, but here's a little light reading...
https://www.yotatech.com/forums/f2/o...ttacks-167704/
Keep me posted.
Old Jan 12, 2013 | 08:51 AM
breugel's Avatar
Well I did two Seafoam treatments waiting for it to cool to change the plugs. The PVC I think was original so it was replaced. I want to get two years out of it till my kid gets out of school.
Why do people do this to cars. I have a 2004 Highlander Limited with 230k on it. If you look in the engine bay it is clean and it runs like a top. Just routine maint.
Old Jan 12, 2013 | 10:27 AM
breugel's Avatar
I replaced the plugs and none of them were oil fouled. They all looked good but worn and the wrong type... Single not double ground. So we will wait and see how it does....
Old Jan 12, 2013 | 07:46 PM
DRCOFFEE's Avatar
Marvel mystery oil should help to slowly dissolve the sludge.
Old Jan 13, 2013 | 09:32 AM
JBurt's Avatar
Check out this thread. TA has good write ups and knows his stuff pretty well.
https://www.yotatech.com/forums/f2/s...y-work-243376/
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Toyvana
Jul 29, 2015 10:47 PM
yourrealdad
Jul 29, 2015 11:08 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
